I think the rub for this group, is that we all operate Power Trac's which do not depend on conventional transmissions or a gear driven rear ends in order to maintain a peak performance.
Due to observations from several of the members on this forum who use the thicker viscosity motor oils, in the 20 w 40-50 range. They report the thicker oil (Does) lesson any power fade under extreme heat, and hard use conditions.
As J.J. mentions, it really depends on the climate you live in, as to using a straight or multi viscosity oil. Most of us will need a multi viscosity of some sort. I do believe either a good synthetic or hydraulic oil is better for my PT over any dino oil. Given the special additives, and in the case of hydraulic oil, it is engineered specifically for hydraulic systems.
So the only question for me would be. Does the higher viscosity (synthetic motor oils) in a 20w40 or even 50 really make that much difference in peak performance. And if so, how much measured harm might they do to the pumps over a period of time compared to hydraulic oils.
Are we talking significant damage or wear as in 500 hours or closer to 1500 hours?
Of course the cost is another big factor for some. In my way of thinking , the PT is a big investment, so I really don’t care about cost (within reason). I want the best oil for longer trouble free pump life, because this little puppy has a lot of hard work to do around here.
Guess there’s no real data out there that can determine this, so we all have to make that call individually. My little 180 came with the standard 10w30 motor oil. It seems to have and maintains plenty of power for anything I need to do around my place. Even though I do notice a (very slight) drop in power when it has been running in the heat for an extended period of time.
Even so, I am (very impressed) with its power, given its small size. That said I will opt for a good synthetic hydraulic 10w30.
