Motorsport Tech Spacers
   / Motorsport Tech Spacers #12
dumptrucking
They will make a spacer to fit your 3032. You need to talk with them and relay the measurements, and then they machine the parts for the price quote.
Check eBay to see several that are listed, and JD 3032 might be there. That is where I started but ended up talking directly to the machinist (I believe) to give him the measurements. All I needed to do is remove two opposite bolts, measure the bolt hole diameter, the spacing across the center for the two bolts, and then the diameter of the hole in the rim. Gave them the size of the lug bolts (M14 x 1.5mm) and they were good to go.
   / Motorsport Tech Spacers #13
Thanks Beenthere,very helpfull.Hey is that you over on the forestry forum with the logging tongs?If so how well do those tongs stay put?
   / Motorsport Tech Spacers #14
The tongs stay put for the most part. If I have a long haul, and some rough terrain, then I may throw a chain around to save stopping and going back if the log slips off from tossing and turning.
   / Motorsport Tech Spacers #15
Love that picture probable the best compact tractor picture I've seen.TRACTORS are made for WORK!!!
   / Motorsport Tech Spacers #17
I'll have ta look for them. Anything in particular? Usually not taking pics when falling trees and bucking them up for firewood. :)
I can't wait for mine to arrive!
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 CATERPILLAR 259D3 SKID STEER (A52709)
2023 CATERPILLAR...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2006 APPA TL (A55787)
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
