mounting a fisher plow on my bx24
   / mounting a fisher plow on my bx24 #11
Why not mount sub frame to the front of tractor and use a link to the bucket to raise and lower the plow. Pull two pins to remove plow to use the bucket. No strain on the bucket mounts that way.
ron
the rest of the plow frame is junk I torched it off libby heating excursion 010.jpg
   / mounting a fisher plow on my bx24 #13
I mounted a 7ft. plow from a pickup to the loader bucket of my Kioti DK35. I cut 2 holes in the back of the bucket, slid the arms into the holes and pinned them.
Next I hooked up a chain from the plow to the middle hook I had welded on to the bucket. It works slicker than sh**. When I take it off, I have 4, 3" square plates with a 3/4" bolt through the middle that I sandwich over the hole and tighten.
If I can figure out how to do it, I'll send some pictures.
pics would be great that sounds like a good idea
   / mounting a fisher plow on my bx24 #15
I would just cut the receiver dog ears off the subframe and weld them to the inside of the bucket. this would allow you to pin the plow on when needed. I'm just waiting to find a cheap plow to put on mine. Is that donor plow truck a '68 I aways wanted one.
Good luck
Phil
its a 1971 three quarter ton and you can have it if you want it is a four speed?
   / mounting a fisher plow on my bx24 #17
I would be interested in the control s,valve bodys,pumpetc,unless you are gonna use them.Im plowing with a73 ford with the same plow,i can always use parts.If you decide to shorten up the plow,or sell it cheap i want to add on mine to make it 9 ft instead of 7.5:) Iwas gonna put it on my bx-23 but my truck runs great and has HEAT:D :D :D
ALAN
2013 International WorkStar 7400 Altec D3060ATR Insulated Digger Derrick Truck (A55973)
2013 International...
NEW 5/16x7ft G80 Chain Sling Double (A59000)
NEW 5/16x7ft G80...
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A58017)
2003 VOLVO VNL...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
