Mounting mirror on tractor ??
/ Mounting mirror on tractor ?? #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
Want to mount a mirror on tractor, It needs to be spring mounted as some of the places I go it would get broken off,
Maybe mounted on FEL bracket, just drill some holes in it???
Suggestions please
Thank you.
/ Mounting mirror on tractor ?? #2
Or use a magnet mounted mirror. Lots of options there. That loader steel could be tough to drill without a drill press.
/ Mounting mirror on tractor ?? #4
I mounted two 5"concave mirrors on my FEL masts. No springs but are on a swivel. There was a hole near the top of mine but it should be easy enough to drill through.
/ Mounting mirror on tractor ?? #5
No drilling needed - use adhesive mounted studs. Mentioned here on TBN = Click Bond, similar available elsewhere (weld mount and others).
Best results if paint sanded down first so it is adhering to the metal.
Prior threads:
http://www.tractorbynet.com/forums/customization/315298-click-bond-mirror-mounts.html
http://www.tractorbynet.com/forums/build-yourself/301748-adding-rear-view-mirrors-using.html
/ Mounting mirror on tractor ?? #6
My dad used Dirt bike mirrors , they have a ball on the end so they can swing and rotate without breaking the arm .
/ Mounting mirror on tractor ?? #7
That's what I eventually did; a single mirror. I'd been pondering how to accomplish having one and off of the FEL mast was the best choice as the ROPS is set too far back.
I purchased, from my local auto-parts store, a large "van" sideview mirror with a 3-screw mounting bracket.On my 300CX, there are two holes already at the top. I made a paper template that would fit inside & marked the hole diameters + high enough to incorporate the mirror mounting bracket... holes marked there also. I then took the template to a local welding/fabrication shop and asked to have it made up using some off-cut steel he might have around = A$30 and a perfect fit! Including the holes.
I picked up the appropriate sized bolts, nuts, washers and lock-washers from the hardware store (after I ensured that the holes lined up). The piece of steel received a primer coat & then a JD Green coat of paint.
A perfect fit and it looks like the tractor came with it. :thumbsup:
I'll get some pictures of it and post. You'll notice that I mounted it on the right hand side. That's for when I drive on a public road as we drive on the left.
Thanks guys, appreciate your input.
/ Mounting mirror on tractor ?? #9
OK, I got off my arse and grabbed some photos of my mirror mount.
I added a piece of cut-up floor mat as a rubber gasket between the plate and the FEL in order to dissipate vibration. It works a treat and the reflection is flawless.
Yes, there's a small JD decal on the back-side of the mirror... I had a 'left over' one that I'd been saving for a future project and this fit the bill. :)
/ Mounting mirror on tractor ?? #10
I stuck some adhesive backed 3" convex blind spot mirrors on the top of my loader masts. Not the greatest position for best view, but better than nothing and quite protected.
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2014 HYUNDAI 53FT DRY VAN TRAILER (A59905)
2014 HYUNDAI 53FT...
2002 Ford E-250 Cargo Van (A59230)
2002 Ford E-250...
2026 tilt trailer (A56859)
2026 tilt trailer...
