Moving crushed stone ???
/ Moving crushed stone ??? #1
Madman_Mark
I've ordered a tandem dump truck load of crushed stone for the 1st week of May.
I've got a long muddy driveway that needs fixing.
Some of the load will have to be dumped out in a large pile because of over head wires (instead of being slowly dumped and spread).
What I'm wondering is how easily my tractor will be able to move this around and spread it out ?
It's a 55HP 4WD with a loader.
All I've really used the loader for is moving snow so far.
I'm sure it will handle it all right but I'm just looking for some hints or tips etc...
Thanks.
/ Moving crushed stone ??? #2
Mark, you can do the spreading pretty easily if you have gotten good at using the loader. Get your bucket full and slowly drop it while backing up. Feather the loader control so that you only drop the needed amount at one time. If you don't have a boxblade to grab and draw it, this should work. If you have larger "blobs" of it after spreading, take the bucket and angle the cutting edge down, put the loader in the float position and drag the high area back, slowing curling the bucket to drop bits at a time until more level. That's one way to do it, I'm sure other members have some good ideas. John
/ Moving crushed stone ??? #3
I had 2 truck and trailers dumped or 4 loads. Two were piled, the others spread. I can spread a pile well before he arrives with the second trailer, about 10 minutes or less. I have a smaller tractor but use my boxblade considerably. With the loader, it still goes very fast. I load it and then once I'm where it needs to go, either in forward or reverse quickly get going all the while dumping my bucket to "spread" it out. My final spreading is with a boxblade but you can do a reasonable job with the loader, just keep the bucket at a very slight angle with the rear of the bucket off the ground about an inch or so.
/ Moving crushed stone ??? #4
I'm doing this right now Mark, it's a breeze. I had three tri-axle loads delivered. They tailgated it some but it still needs spreading and smoothing. Stone is about the easiest to work with as it flows well. As others have mentioned, use your FEL, box blade or just about whatever you have. I'll finish mine up this morning with a few passes with my landscape rake turned backwards. I like the way it fills everything in without actually moving much material around. I may then rent a compactor to run over it as this is not our everyday drive. Vehicle traffic is normally enough to get a good pack but be sure to drive completely, edge to edge.
You've got plenty of hp for the job, what implements do you have?
/forums/images/graemlins/smile.gif
/ Moving crushed stone ??? #5
I've lost track of how many times I've done this with my little L3130(32hp). Scoop it up and feather the FEL down so it just stats to fall out and start moving backwards. Feather the FEL down while backing up. You'll get the hang of it pretty quick.
You can also spread it with the FEL as well. Put the FEL in float and drive backwards. If you curl the bucket all the way back, going backwards, it will start to dig and carry a small amount or material with it. I call it the poor mans box blade....LOL!
Anyway by adjusting your roll angle you can carry a little material and then roll the bucket down when you need to fill a little more and smooth. It will probably take you two minutes to figure it out.
RobS, I have the FEL and a Farmi logging winch on the back, nothing else so far, maybe a wood splitter and a bush hog eventually.
The winch has a large but plate/blade on it which I could use for leveling stone.
Thanks for all the great advice.
/ Moving crushed stone ??? #7
mark: all the guyd gave u good advice on the way to do it,but the best teacher is to just saddle up and get at it. u will soon learn for yourself the best way to do it.
/ Moving crushed stone ??? #8
</font><font color="blue" class="small">( mark: all the guyd gave u good advice on the way to do it,but the best teacher is to just saddle up and get at it. u will soon learn for yourself the best way to do it. )</font>
You are exactly right about that Frank. Nothing like on the job training to learn. John
/ Moving crushed stone ??? #9
Piece of cake... you could do it with a box blade or rear blade or dirt scoop on a smaller tractor, and just take more time, and have a sore neck a couple days later.. your setup sounds virtually 'ideal'.. loader is deffinately a ++ tool.
Soundguy
/ Moving crushed stone ??? #10
Mark,
I just did 60 tons of stone on Monday and Tues last week to make a new driveway. I had the stone delivered in a stone shooter. They were able to spread the stone evenly up to 30 feet from the truck at a rate of about 20 tons per half hour. The operator would spread stone evenly over the closest area to about 30 feet from the truck then backup over the stone he had just laid and do the next section. I then touched up using the FEL and the BB. Use of the stone shooter added about $50. per load to just having the stone piled. It wasn't expensive and made the job a lot easier than spreading it with the tractor.
Bill
/ Moving crushed stone ??? #11
Two tips. First of all, have weight on the 3PH and carry the load as low as you can. This will help keep all 4 wheels on the ground.
Also, I had much better results using the loader without the toothbar attached.................chim
/ Moving crushed stone ??? #12
I've spread a lot of rock with my little B2710 with loader and box blade, so you shouldn't have any trouble.
/ Moving crushed stone ??? #13
<font color="blue"> I had the stone delivered in a stone shooter. </font>
What's a stone shooter?
/ Moving crushed stone ??? #14
It is a huge 40 ton truck with a 20 ton capable hopper and two conveyor belts. One at the bottom of the hopper and one on a hydraulically controlled 20 foot long ramp. When the operator opens the hopper stones fall on the low speed belt below the hopper. Stones are conveyed to the second belt on the ramp that can be elevated and trained and speed controlled by the operator. You can see one on the bottom of the page at this link <font color="blue"> Stone Shooter</font> It was highly recommended by a contractor friend and it was a great time saver.
Bill
/ Moving crushed stone ??? #15
That stone shooter gizmo is pretty cool. I haven't seen one before. /forums/images/graemlins/blush.gif
/ Moving crushed stone ??? #16
Mad Mark,
Hey, I'll come over and do it for ya--what kinda tractor do I get to play with...errr work with! It is easy and fun...really. This is not one of those nasty jobs. Although I think stone throwers are awesome (and some of those operators are true artists with those things) I think a regular tandem load will be fine. Either way you'll have a littl final spreading to do. If you want a "perfect" surface try a landsacpe rake for the final. Personally I think a driveway needs to be good and funtional and not perfect...i.e. I'm happy driving the tractor but I don't want to get off of it and work by hand!!! /forums/images/graemlins/shocked.gif
Have fun,
Peter
/ Moving crushed stone ??? #17
That looks pretty cool, never seen anything like it around here. I was envisioning a stone cannon of some sort. The pro landscapers here are using a blower system to lay down mulch now. Kind of like an insulation blower on steroids. Feeds the mulch through four inch soft corrugated hosing. They can do an entire subdivision home with the truck parked on the street.
I suppose my version of a stone shooter could be somewhat dangerous /forums/images/graemlins/smile.gif
Informational Lot - Shipping (A63118)
Informational Lot...
Kubota L4701 MFWD Tractor (A64047)
Kubota L4701 MFWD...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
