Mower cuts better in reverse ?
   / Mower cuts better in reverse ?
Check the deck pitch
I have always had the deck level or pitched slightly higher in the front. I have heard others say to pitch the front down a bit. What is your suggestion?
   / Mower cuts better in reverse ? #12
Me: Lower at the front.
   / Mower cuts better in reverse ? #13
That's your problem....the pitch is wrong. You want the front lower by just a slight bit.
   / Mower cuts better in reverse ? #14
Sounds like a good candidate for a DR field and brush mower, or similar. Mine is old, but handles 12 inch grass like a lawn mower cuts 4 inch grass down to 3 inches.
   / Mower cuts better in reverse ? #15
Yep, front lower. Probably why you are cutting better in reverse. Since back is lower.
Thanks guys, I'll make sure the front is lower. Think about 3/8"?
   / Mower cuts better in reverse ? #18
1/8-1/4" is about right on a finish mower
   / Mower cuts better in reverse ? #19
Agreed.. just a bit lower on the front.
   / Mower cuts better in reverse ? #20
I''m surprised nobody mentioned the obvious cause of a mower cutting better in reverse:
His grass is growing backwards. Gotta get that root cause fixed. No adjusting the machine will help.
:D
Okay, seriously, it's riding mower, right? It's not made to cut 12" grass, and that's got nothing to do with what people in town like or don't like. It's what the machine was made to do. You can adjust it til the cows come home and it's going to do a lousy job on 12" grass.
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
TANK MANIFOLD (A58214)
2018 JAGUAR XE Sedan (A56859)
2018 JAGUAR XE...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
SET OF TRUCK FENDERS & HARDWARE (A58374)
SET OF TRUCK...
