Mowing in reverse
   / Mowing in reverse #11
My JD LT180 had a switch also, my BX doesn't. Just step on the back pedal and mow.
   / Mowing in reverse
Good to know, Thanks. My old mower automatically disengaged the blades when you stepped on the reverse pedal. Also I wasn't sure since the mower deck is angled slightly to keep the leading edge of the blades a touch lower than the trailing edge to help keep the tip speed up.
This is my first real tractor, and I don't want to mess things up by committing rookie mistakes. I have also learned that it is best to take the FEL off when mowing to avoid accidentally knocking over random items with the front end while watching the back.
I have thought about "accidentally" running over some of the trees, but she is excited about them. Seems rotten to spoil something that she enjoys. Plus about a third are Pecan trees. I am looking forward to those getting a little bigger. The flowering ones are the ones that would be in real danger.
I did hand her the trimmer after she finished with the shovel though. She made it about 30 minutes before she had to quit because her arms gave out. I told her she has wimpy girl arms and she was back out there the next day. That was the desired effect.
ahoglen: Yes, I was referring to the tractor direction, not the PTO direction. Not sure that it is possible to do that.
Another question:
If the gearbox has a bit much gear oil in it so that it seeps out of the overflow port when it's in use, will that hurt anything? Should I drain a bit out or just let it work itself out? I do spray it off after every mowing as the whole rig gets pretty dusty if it's dry out.
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
(50) 2" X 2" X 41" TUBING (A54756)
(50) 2" X 2" X 41"...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A55788)
2015 Chevrolet...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
