Mowing Speed Kubota L2501
   / Mowing Speed Kubota L2501 #41
It has been a couple of months since I posted this thread. I have learned a lot on TBN but have also learned how much more there is to learn. Since the original post was about cutting as quickly as possible here is an update.
I ended up with a 40 hp and a 72" Land Pride BH. The tractor is not a easier, more comfortable, ride than my Exmark at any significant speed. It is still very bumpy and at times much worse. The speed that I am able to travel is much lower than I anticipated so even with a much larger deck, 42" vs 72", it appears the tractor will take as long or longer to cut the property.
Of course with a tractor and BH I can cut less frequently if I choose too. Still very happy with the tractor purchase and feel it was the right choice for my needs,
My zero turn rides a lot better than my tractor mowing at higher speeds also.
Taking the loader off to mow does help some with the ride.
   / Mowing Speed Kubota L2501 #42
Of course, $$$ comes into the formula. I would go with the HP tractor that best fit my needs. Then I would match it to an appropriate sized bush hog mower. Say the specs suggest a six foot mower. I would consider getting a 7 or 8 foot mower. My logic is if the field is brush and overgrown, I would go to a lower gear in the tractor so the mower could handle it. Then if/when I mow more often, I can speed up and get the mowing done faster.
As a kid, I operated a ford tractor and six foot mower to cut pastures. You drive round and round and round and round for hours--it's tough to see any progress. And if you got to a thin area where you could speed up, the tractor beat you to death.
Ron
Are you running with the loader on. I致e been mowing with the loader on for years and I discovered by accident that it rides mulch smoother with it off.
Yes, I have been mowing with the loader on. I will try it with the mower off soon.
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2019 Komatsu WA470-8 Articulating Wheel Loader w/Quick Coupler, PIN# KMTWA129JJNA49506, Turbo Die... (A59076)
2019 Komatsu...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2015 Chevrolet Cruize Sedan (A56859)
2015 Chevrolet...
