Mowing with an IH Cub?
   / Mowing with an IH Cub? #31
That's slick:thumbsup:
when i bought the cub and mower.. I got it a lil cheaper as the owner said the mower hub was stripped and wouldn't turn the blade.. he had reversed the direction of the belt by twisting it on a couple pullies and it was driving the orc in free-wheel direction :)
unfortunately.. he had bolte the blades on to cut in that direction.. IF it had cut.. so had to swap those as well.
some people.. :)
   / Mowing with an IH Cub? #32
some people.. :)
Sometimes you gotta do what you gotta do:eek:.
Right now I'm struggling with the disc openers on my JD 71 Flexi-planter. The discs aren't turning freely so I need to remove them and probably replace the sealed bearings (it's a two-row planter). The little hex head screw-on caps have to be removed to get at the socket head bolts that hold the discs onto the planter. These hex heads are so worn that I can't get a socket on them. I'll try an easy out but I never have had much luck with those things (they usually break off). I'll probably end up welding a washer and hex head nut onto the cap. Idiotic design on JD's part.
   / Mowing with an IH Cub? #33
yep.. probbaly bad design.
if you do ddrill for an ez out.. I've found the best way to help success is to drill as large a diamater as you can while not getting out of the bolt, this relieves pressure and allows the bolt to deform inward if needed, and also lets you use a larger extracor. I like square profile extractors vs fluted spiralones myself.. but have both and haveused both.
also.. any time I pull a bolt / nut off/out, if it is wore.. especially the inverted square and allen, I repalce it.
nothing like getting a stripped inverted allen out.. :(
   / Mowing with an IH Cub? #34
Well I had a 50's cub, red in color, Flat-head.not a low boy. The engine was fine when it wanted to run. We pulled it a lot to start, finally re-wired it and new ignition. It had hydra lift, not all have that. It would tip easy on one side due to offset seating, and i did not have the wheel weights. It nearly tipped twice while i was mowing. It had 100 blade mott mower under it. A lot of sharpening involved. I still have a bucket of blades for it and a Ford mott...We sold the cub cheap, it had used me up...and my patience..
   / Mowing with an IH Cub? #35
IMHO.. not alotta hp for a flail on a cub.. but they run a sickle bar decently.. even up to a 5' bar.. similar to an allis G.. etc.
soundguy
   / Mowing with an IH Cub? #36
Sg, that is right on, I had brand new piston rings and valve job. I had to weld up the water jacket on the head, with nickle rods. You engaged the mower in no grass or raised position and it did not like high grasses? I believe it was 4 ft wide...
   / Mowing with an IH Cub? #37
flail mowers are natures way to make you mow slower and need more hp to do the same job of another type of mower AND add more cost and maintenance :)
soundguy
   / Mowing with an IH Cub? #38
As I said earlier my Dad mows hay with a 5 foot sickle bar side mount mower on his cub every year. Not lots of hay, just enough for 2 or 3 beef animals. Pretty good for a guy in his 80's. Pretty good for a tractor in its 60's.
   / Mowing with an IH Cub? #39
i'd love to find a decent sickle bar mower. not very popular down here.. thus hard to find...
   / Mowing with an IH Cub? #40
The area does have a lot to do with it. Right now I can find you two sickle bar mowers for a cub within 7 miles of out house. They are pretty common around here and you see a lot of Cubs working. Most people get them because they are FAR stronger than a "garden tractor", easy to find parts for and can run tons of implements.
Mine is slowing going back together as I am completing a FULL rebuild (all new seals, bearing, 100% engine rebuild, etc...) only to be used for mowing the yard and putting a sickle bar on for trimming along our road. I have a 37hp Kubota but would rather mow with the Cub!!
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
12ft. Flatbed Truck Body (A59230)
12ft. Flatbed...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
