MX5100 3-remotes under $500 and TNT under $400. Details.
   / MX5100 3-remotes under $500 and TNT under $400. Details. #11
I just get a link that takes me to "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
I hope that fixes the pictures. Sorry it took so long. Had to go try out the blade with the TNT. It works as expected. Before I went out, I noticed that there were no pics in the posts, just the words "attachment" that was blue, but it still worked when I clicked on them. But not when I got back in.
Never had this happen, and its not like its the first time I have attached pics, so I am about 98% sure the issue was not on my end.
I just re-attached everything. Man my upload speed is slow....
   / MX5100 3-remotes under $500 and TNT under $400. Details. #13
Ld1 as the owner of an l3600 I almost wept in joy at seeing your post. Once the finance committee see the new numbers instead of the oem ones I might have a chance at tnt. Thanks a million especially for all the pictures. Everything is better with pictures when your as dumb as I am
   / MX5100 3-remotes under $500 and TNT under $400. Details. #14
Very nice job LD1. You should be proud of it. Are you going to put in the third set of remotes too. And what of the front?
   / MX5100 3-remotes under $500 and TNT under $400. Details. #15
Got all pics.
Nice job, need to find a few bucks to do that to mine now.
I really appreciate the great write up including all the parts
   / MX5100 3-remotes under $500 and TNT under $400. Details. #16
A+ work -- nice job!
   / MX5100 3-remotes under $500 and TNT under $400. Details. #17
Very, very nice.
What the metal thing mounted to the left of your aluminum QD mount? Where the OEM tool box was?
   / MX5100 3-remotes under $500 and TNT under $400. Details. #18
As promised, a new thread detailing the 3 remotes and TNT build.
Here are the parts used. For most of the fittings and adapters and hoses, I'll quote DHH or Surplus center prices, allthough I didnt need to order any from them. I had most of what I needed already, and what I didnt have, I ordered through work. So the hoses and fittings prices are just so others can compare and see what is needed for the total project. And may not match up to exactally what I did, because I was working with what I had. IE: I didnt have a -10 ORB x -08 JIC 90* fitting, but I did have a -10 ORB x -10 JIC 90* as well as a -10 x -08 JIC reducer. But if I had NOTHING at all, what I would have ordered is what is listed.
Master parts list for 3-remote install:
Chief 3-spool valve with 1 spool float. Baileys # 220959 .....................$185
Chief PB plug for above valve.............Baileys # 220915......................$20
(6) Pairs of pioneer 4200-4 couplings......Napa # BK VP42004 $20ea.....$120
72" of 1/2" hose to go from loader PB to remote P....surpluscenter # 940-2272......$21.95
Hose to go from remote valve PB back to tractors manifold.....reused the hose that originally went from the loader valve PB to the manifold..........FREE
36" of 1/2" Hose to go from remote valve tank port back to tractor manifold Surplus center #..... 940-2236........$16
(6) 3/8" hoses 24" long to go from remote valve to couplers....surplus center #...930-2224...$10.95ea...$65.70
(3) Adapters to make the 1/2" hoses attach to the valve -10orb x -08JIC 90*..DHH # 6801-10-08..$3.34ea...$10.02
-08 JIC tee to tee in the return line at tractors manifold block.....DHH #2603-08-08-08.......$2.87
3/8" NPT male x -08 JIC female swivel to attach above tee to manifold on tractor......DHH #6505-06-08.......$4.05
(6) -08 ORB x -06 JIC adapters to connect hoses for couplers at the valve....DHH # 6400-06-08......$1.54ea.......$9.24
(6) 1/2" NPT x -06 JIC 45* adapters to attach the quick couplers ...DHH # 2503-06-08.....$3.12ea........$18.72
(6) QC caps....................$1.90 ea..........$11.40
Bracket to mount the valve.......made with scraps......FREE
Block to clamp-mount the couplers.....Made in house......FREE
TOTAL $484.95
Satisfaction of doing it myself......priceless.....or at least the ~$2k I saved over OEM.
Now for the TNT parts list:
3" x 6" Maxim cylinder......bailey # 288427.......................................................................................$125
3" x 12" Maxim cylinder.....bailey #288431.....................................................................................$140
(2) Category II ball ends......Agrisupply #11914.......................................$3.99ea..................................$7.98
Category I ball end (for sidelink) Agrisupply #11913.......................................................................$3.99
(2) 36" 3/8" hoses.........surplus center # 930-2236...................................$12.95ea.............................$25.90
(2) 30" 3/8" hoses.........surplus center # 930-2230................................$11.95ea...............................$23.90
(3) -08 orb x -06 JIC to adapt cylinders to hoses.......DHH # 6400-06-08.......$1.54ea.......................$4.62
-08 orb x -06 JIC 90* to adapt cylinder to hose.........DHH #6801-06-08............................................$2.55
(4) 1/2" NPT male x -06 JIC to adapt male half of coupler to hose....DHH #2404-06-08....$1.01ea.....$4.04
(4) dust caps...........................................................................................$1.90ea.......................$7.60
TOTAL $345.58
Shipping for ALL of above including the remote stuff.....$42.26
Grand total for 3 remotes AND TNT setup.....$872.79
Now....on to the build details and pics.....I will politely ask if everyone waits till I get through everything before posting. Details will come in a series of replys to this thread, as to not have everything in one single post.
Could you give a link to the baileys website plz
   / MX5100 3-remotes under $500 and TNT under $400. Details. #19
LD1 Thanks for taking the time to detail everything you did and bought. It really helps us guys out that don't do a lot of hydraulic work.
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A53472)
2023 NEW HOLLAND...
Electric Concrete Mixer (A51573)
Electric Concrete...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
Unused Delta Crash...
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
