My 1601D Yanmar won't Idle?
   / My 1601D Yanmar won't Idle?
Thanks Everybody who replied and to HoyeTractors for their diagrams. :)
I went straight to Hoyes and went to they're interactive parts lookup (1500D) for my engine and there it was DISC PLATE Wah-Hoo. I know this is the problem, now that I think about it and will fix tommorow!
Thank You TBN and the knowledgeable people who Lurk here! :) JK
   / My 1601D Yanmar won't Idle? #12
yes, That friction disk will go bad (wear out) over time. You have to rember,that disk may have been on the tractor since it (the tractor ) was new 20 ??? yrs ago. Good luck
   / My 1601D Yanmar won't Idle? #13
hey, let me ask you guys a question... on my 1601, while plowing a long row or hogging a long run on field, i notice a drop in rpms--- i then push the throttle lever forward a bit (or is it back, can't remember between the tractors..)... Anyway, could this be throttle disk related? thank you.
   / My 1601D Yanmar won't Idle? #14
I think your throttle disk is slipping. Both Yanmars I bought I had to tighten the disk. Think maybe yours just needs tightening.
   / My 1601D Yanmar won't Idle? #16
I had to tighten mine too. It did the same thing. Would be set at 2200 and 10 minutes later it would be down to 2000.
   / My 1601D Yanmar won't Idle? #17
My disk was just worn out period. I purchased a new one & now all works great !
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
Bobcat 22in. Excavator Bucket (A53117)
Bobcat 22in...
Eaz-Lift Elite Weight Distribution Hitch Kit (A53117)
Eaz-Lift Elite...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
Miller Dimension 302 Welding Machine (A53117)
Miller Dimension...
