Yesterday, I finished grinding, sanding, and sandblasting the hydraulic lift cover, then primed it. After the primer dries, I'll begin filling minor casting flaws with Bondo, then sand and prime them again.
Today, I disassembled the position/draft control quadrant lever assembly and have begun sandblasting all the parts. That said, I've begun to think about what color to paint it and other parts of the tractor. Most of the position/draft control quadrant lever assembly parts were originally galvanized or aluminum so I want to go with colors that faithfully recreate the original look.
The following is a list of various parts and the colors I'm thinking of painting them. Note that the list excludes the chassis and sheetmetal which will be painted with the appropriate Massey Ferguson colors for each.
Galvanized Color:
* Position/Draft control lever assembly
* Headlight bucket brackets (red buckets)
* Radiator cap (black for now)
Cast Aluminum Color:
* Carburetor body
* Distributor body
* Draft response lever (lever and knob only)
* PTO control lever (lever only) (Black/Red knob?)
* Oil filler cap
* Grease fittings
* Coil bracket
* Air filter assembly
* Gear shift levers
* Gas tank (possibly grey)
* Throttle lever (real chrome?)
Brass Color:
* Transmission vent
* Throttle bushing
* Assorted carburetor parts
Black Color:
* Voltage regulator
* Coil
* Startor
* Generator
* Radiator
Real Chrome: (May be cost prohibitive)
* Emblems
