I've been contemplating how I want to repair some of the cast on my 135, the previous owner was a poultry farmer so I have some corrosion issues as well, your post about repairing corroded areas got me thinking about some of the products we use on aircraft.
Floorboards are an integral part of an aircrafts structure, sometimes made of two aluminum sheets laminated over a foil honeycomb core. When damaged / punctured we will drill out the damaged area and patch it, using a product similar to the two part liquid metal Devcon listed below as a filler to replace the damaged foil honeycomb. It has exceptional bonding and corrosion resistance characterisitcs. I've used it for smaller projects and have achieved excellent finishes using plastic to form the product immediately following application. When cured the plastic can be easily peeled away, leaving a finish that is so well formed and smooth only minor surface preparation is required prior to finishing.
For myself, I would only plan to use it for areas where the pitting is significant enough to warrant it, and because I'm someone who usually goes further than is required (what my wife refers to as ****) when doing this type of work, I'll be looking to buy more than the small tubes of the two part Devcon found in most box stores.
I've found a few addresses of different companies that manufacture similar products, I haven't had the time yet to really research what each has to offer but from what I've read so far I am strongly considering it over a normal bondo, thought you might find them interesting.
A. Devcon Corporation
30 Endicott Street
Danvers, MA 01923
800/933-8266
B. Belzona, Inc.
2000-T NW 88th Court
Miami, FL 33172
305/594-4994
C. Dumond Chemicals, Inc.
1501 Broadway
New York, NY 10036
212/869-6350
D. Diedrich Chemicals Restoration Technologies, Inc.
300A East Oak Street
Oak Creek, WI 53154
414/764-0058 or 800/323-3565
