Forester Massey
Bronze Member
It sounds as if your tractor probably needs an engine overhaul. Granted, it's possible that the loss of compression on cylinders 2 and 3 could be from bad valves, but I doubt it. Likewise, the fouled plugs could be caused by worn valve guides or bad valve seals, but because you're losing compression on two cylinders I believe the oil which is fouling the spark plugs is coming from the oil control rings.
If you do find that your engine needs an overhaul you could do an in-frame overhaul, but I believe it's much better to bite the bullet and pull the engine to do a complete overhaul which will permit you to replace the rear main seal as well as inspect and/or replace the clutches. Some people may advise that you "split the tractor", but I've learned that it isn't much more work to simply remove the front-end assembly before pulling the engine. I did mine in a single evening, but the choice is yours to make.
Don't let the things I've found during the course of my restoration project discourage you. I'm being somewhat picky because I'm doing a complete restoration, but if my Massey 135 tractor were intended to be an average working tractor I would have done things very differently. For example, I would have probably have just given it a valve job and made some minor repairs before calling it a day.![]()
I am excited to do the project. I have sent an oil sample in to see if it confirms what I think. I am planning on taking the block off for ease of working on engine. I bought a video of this at from yesterday's tractor that shows them doing a complete engine rebuild on this same model. Since I am a better visual learner it will help. I also bought a shop manual.
I found that I can buy what is called a comprehensive overhaul kit that contains pistons, sleeves, rings, valves, valve seals and guides, all gaskets, bearings as well as radiator hoses, plugs, filters, carb rebuild, points, plugs, oil pump rebuild. All for $800. I need all of that stuff since the mice chewed through anything they found tasty.
In the video, taking the front end off was not a big deal except for a stuck ty-rod that had to be heated. I will let you know how it goes and will watch for your updates.
