My 3 point trailer hitch project
   / My 3 point trailer hitch project #11
Now just weld some hooks on and get a hook for reciver and you can pull trees or post out of ground.
meanmerc,
You might try bolting the receiver to the underside of the drawbar, then you can use a plate on top w/the same bolts to weld the upright bar to. That's the way I'm thinking I should have done it, since the ball is a bit higher than I anticipated.
Then you can unbolt the receiver anytime to move it to your bucket if you like.
Jim
I got the same idea, I already bolted the receiver to the drawbar now just have to weld up the up bar but I've been hesitating now cause I might use that receiver and bolt it up to the bucket (FEL) instead!!!:confused:
johndeere4300,
It's actually the pin that is sticking inside. I think the lip on it is catching, like the holes in the receiver and tongue aren't lining up correcly. I briefly tried a punch, but didn't spend too much time on it. I'd probably have just wound up crushing the end, or snapping off the end if I had continued. I'm sure with a bit of wiggling and patience, I'll get it apart.
Thanks,
Jim
<snip>
Jim,
That is a nice job you did also and we like pics. here on TBN.
You said it was stuck in your hitch.
Can you take a piece of 2x4 and lay it against the ball and hit the 2x4
with a small sledge and get it out.
Thanks for the pics.
   / My 3 point trailer hitch project #14
johndeere4300,
Thanks,
Jim
Ok.
I understand you now,
Anyway you could take a drill press and drill both of them.
   / My 3 point trailer hitch project #15
yeagisyeag, yes hindsight is 20/20. But that is what I like about steel, it is usually very forgiving. Easy to cut it apart, grind it off and do it again. I have been using mine for over 10 yrs and was thinking it seemed a little high bolted on the top. There have been situations where mine was needed very close to the ground.
Meanmerc, bolt it below the drawbar and add a plate to weld the upright for the toplink to. Very easy to unbolt and use on rear or on front bucket.
   / My 3 point trailer hitch project #16
This is what I built last Summer. Hauls trailers, pulls logs and it serves as a weight box as well. I can add 600lbs of ballast on the 3ph that is including the weight of the contraption.
   / My 3 point trailer hitch project #17
Great ideas from all! Thanks for posting Is there a need to limit uplift travel with the hitch?
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A56435)
2019 Cadillac...
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
1302 (A58374)
1302 (A58374)
2014 Ford Escape SE (A56859)
2014 Ford Escape...
