Snow Attachments My $8 Snow Blade
   / My $8 Snow Blade #11
I'm glad to see you got such a good deal! I've never been able to find a good deal on anything at auctions, there's always someone there willing to pay near new prices for old stuff that they don't even know if it works or not.
   / My $8 Snow Blade
Danny,
I watched them toss out a TV no one bid on. No electric in the barn to try it.
Then saw a 5' Caroni RFM go for over $600???
Then a 1987 Ford T-Bird Turbo Coupe only brought $800.
A non-running, no keys, no title, fiberglass bodied dune buggy sold for $2000.
Who can figure it out?
   / My $8 Snow Blade #13
a search of the great TBN forum would have given you some idea: /forums/images/graemlins/smirk.gif
sorry, the URL posting function is not working this AM:
please, look under Power Trac/ Cheap Snow Plow ... we used this plow here in the south eastern part of pa during the Presidential Snow Storm, commercially (with great success) /forums/images/graemlins/smirk.gif
   / My $8 Snow Blade #14
Inspector,
Take a look at my web page to see what I did with a 42" front blade on my YM1301D. I used cables and sheaves to lift it with the rear 3pt hitch. I attached a photo here for a quick look.
   / My $8 Snow Blade #15
Oh,
Sorry to burst your bubble Inspector - my 42" blade was given to me for nothing...
   / My $8 Snow Blade
Actually Greg I dug your website up this morning because I knew you had done it /forums/images/graemlins/grin.gif
I've got a 42" out in the shop that I had for my Craftsman, but it was just too small, where as this 52" will be just about right.
   / My $8 Snow Blade #17
Yeah,
42" is too narrow for my tractor too. I've got a line on a JD 54" hydraulic lift and angle front blade. The 1301D has a quick detach loader that leaves the hydraulic valves on the tractor, so I've already got the hydraulics. Unfortunately, if I remember right, the JD317 it came with uses only about 600psi hydraulics. I don't know if the cylinders will take the higher hydraulic pressure of the tractor.
   / My $8 Snow Blade
Can you get a regulator/relief valve to reduce the pressures?
   / My $8 Snow Blade #19
A relief valve was pretty much what I had in mind. Or I might just be able to replace the cylinders with higher pressure rated cylinders. I kind of like the relief valve idea better as it might protect the blade better from overstressing with too much hydraulic force.
   / My $8 Snow Blade
Well, here it is mounted. The blade is raised by the 3ph in the rear, using cables, pulleys. There are a few glitches, but I can work them out.
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
2015 TEXAS PRIDE  GOOSENECK (A52472)
2015 TEXAS PRIDE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2012 DIAMOND CARGO FOOD TRAILER (A52472)
2012 DIAMOND CARGO...
2012 John Deere 7230R (A52748)
2012 John Deere...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
