My attempt at a SSQA for Kubota
   / My attempt at a SSQA for Kubota #1
countrybumpkin
Elite Member
Kioti, kubota
Well I have been wishing I had a SSQA for a long time just never could see spending the money for one, so I finally broke down and built one With scrap I had laying around and some stuff from work. I have about 100 dollars in the whole project after buying paint and a few other minor stuff.
Here are some Adapter pics
And now for some of the bucket before and after.
   / My attempt at a SSQA for Kubota #3
Looks sharp,
Was that MIG, TIG, or stick
Nick
It's all mig, Millermatic 250. Thanks
   / My attempt at a SSQA for Kubota #5
Very nicely done.
Looks great.
Thanks everyone, wish I had taken a lot more pics from start to finish. Just got to involved building.
   / My attempt at a SSQA for Kubota #9
did you fab all the hardware for the locking mechanism yourself or buy that as parts from bobcat or the like?
No I fabbed everything my self with simple hand tools, I did buy the two springs holding down pressure on the locking pins, the two black springs under the handles that hold them up in the unlocked position are heavy valve springs from a ford 302.
Handles were cut from 3/8" plate with a torch
Pins were cut from 1" square stock with a chop saw
The bolts going from the locking pins to the handles were 1/2" grade 8 6" long then I cut the heads off and flattened one end to insert in the locking pins.
The base plates were 8" wide 1/4" think C channel Then boxed the top edge with 2" wide 3/16" angle
The boxed in area were the loader pins mount set on some 3" X 2" x 1/4" angle
I cut off and reused the loader arm mounts from the bucket.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
2014 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2014 Ford F-150...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
