My BX22 Front axle vent
   / My BX22 Front axle vent
Garrabo,
I have a one way valve on the end of the vent tube. I got it off of an old chevy 4x4 transfer case vent.
Jeff
Bluecon1,
Thanks.
My vent is a one way valve---but I wonder if some sort of filter would be better. I might look into that.
Regards,
Jeff
The finished product with steel braided line.
   / My BX22 Front axle vent #14
That thing is far to clean mine has not been that clean since the first day I owned it. Second if you try and push any kind of brush you are gonna rip it off. Would not last one day on mine. I had to build a brush guard to keep from tearing the loader hoses off. I think you fixed something that was not broke. But it is pretty.
Jimbrown,
Sounds like you're getting your money's worth out of your machine. I agree, any rough work in thick brush would most likely pop the hose off. Fortunately I don't have any of that stuff around my place to worry about. I would remove the hose and cap the fitting if I ran into that type of work.
Regards,
Jeff
   / My BX22 Front axle vent #16
Jeff, What type of fitting did you use in place of the plug on the front axle? I took the plug out and the threads do not appear to be pipe thread, they look more like a straight thread?
Thanks
Frank
Frank,
I drilled out the original fill plug and tapped it for a 1/8" npt. The plug is pretty soft and easy to drill in a press.
Jeff
Loegering Metal Tracks (A50774)
Loegering Metal...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
John Deere 648R (A50121)
John Deere 648R...
2239 (A51244)
2239 (A51244)
2015 Peterbilt 348 T/A Fuel Lube Truck (A50323)
2015 Peterbilt 348...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
