My BX22 Front axle vent
   / My BX22 Front axle vent
Garrabo,
I have a one way valve on the end of the vent tube. I got it off of an old chevy 4x4 transfer case vent.
Jeff
Bluecon1,
Thanks.
My vent is a one way valve---but I wonder if some sort of filter would be better. I might look into that.
Regards,
Jeff
The finished product with steel braided line.
   / My BX22 Front axle vent #14
That thing is far to clean mine has not been that clean since the first day I owned it. Second if you try and push any kind of brush you are gonna rip it off. Would not last one day on mine. I had to build a brush guard to keep from tearing the loader hoses off. I think you fixed something that was not broke. But it is pretty.
Jimbrown,
Sounds like you're getting your money's worth out of your machine. I agree, any rough work in thick brush would most likely pop the hose off. Fortunately I don't have any of that stuff around my place to worry about. I would remove the hose and cap the fitting if I ran into that type of work.
Regards,
Jeff
   / My BX22 Front axle vent #16
Jeff, What type of fitting did you use in place of the plug on the front axle? I took the plug out and the threads do not appear to be pipe thread, they look more like a straight thread?
Thanks
Frank
Frank,
I drilled out the original fill plug and tapped it for a 1/8" npt. The plug is pretty soft and easy to drill in a press.
Jeff
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
John Deere 4020 (A50120)
John Deere 4020...
Wood Fence Posts (A50121)
Wood Fence Posts...
2015 Ecoline 7 Ton T/A Equipment Trailer (A50323)
2015 Ecoline 7 Ton...
