bellweather
Platinum Member
Not sure about other BX tractors, but the BX22 does not have a tachometer.
I have had my BX for three years now and just started mowing my one acre with the MMM. I notice when doing FEL work or roto-tilling the yard the temp only moves up about a quarter of the temp gauge. When I mow the temp goes up to about 1/3 of the gauge.
Does this seem normal? I work the BX pretty hard with the FEL and tiller. Seem the temp should not change. It has not gotten hot here yet. Not even 80 deg. I worry about what the temp will do when the temp gets up in the upper nineties or hundreds this summer.
The mower deck probably requires more HP than you think. Plus, with mowing you are actually driving the HST continuously. With tilling, you move a little then wait, the move a little, then wait. Do you use low range when tilling?
My biggest problem when mowing is plugging the radiator and screens. After two or three hours of mowing, I have to blow air rearward to clean out the radiator. Sometimes I remove the battery and use a shop-vac. Regardless, when not plugged, my BX runs no hotter than its "warmed up" indicator.
This is a good point. I often find a build up behind the battery even though I check and clean the radiator screen often. Sometimes just brushing off the front of the "battery grill" can make a difference. It is right in front of us and often we don't notice the build up.
I am relieved to hear this discussion. Both my own BX2200 and my daughter's BX2200 run "hot" when mowing. By "hot" I mean well above mid range, not in the red. Never goes in the red but certainly gets to 90% of that on the temp gauge. I use the 60" deck only most of the year but run that plus the PTO driven bagger in the fall. These attachments put more load on the 3 cyl than anything else I use (way more than a 40" tiller, way more than routine FEL work.) From what I hear all of you say this "running hot" is the nature of these machines, especially in very hot weather at full tilt with the 60" mower deck. My guess is "all is well" but I think they need a higher flow water pump. The radiator seems plenty big for that size engine.
Just because the temp gauge indicates a higher temperature doesn't mean the engine is overheating. A key distinction between gas and diesel engines is these little diesels are made to operate continuously under a full load, where they run most efficiently at a nice toasty temperature. Giving the thing more cooling capacity so it could run cooler would be the wrong thing to do. True overheating, where the coolant is gone, can be catastrophic of course, but damage can also occur if it never gets hot enough.
It sounds like your radiators on your bx and your daughters machine are partiality blocked with grass clippings, my father in law has the bx1850 and it started running hot this year mowing but only in thick grass, ,i removed the screen under the dash , slid battery out and the radiator was half way blocked a minute with the handheld leaf blower and all is well again.
