Timber
Veteran Member
I know with my Brush mower I keep the clutch in and the engage the PTO. Then I release the clutch. I'm not sure what your doing but the shaft should turn real easy
My guess tooUh, are you seating in the seat when you engage the PTO? If not, push the seat forward. Safety switch????
z0lt3c said:However, as soon as I engage the rear PTO handle, the tractor immediately stalls. I've tried it at full throttle and it still stalls and in low and med gears. I don't see anything binding, but I can't seem to move the shaft freely (by hand) when it's attached to the rear PTO but PTO not engaged... should it turn freely?
MarkLeininger said:You probably can't turn the shaft easily while it's attached to the tractor, but if you disconnect it the shaft should turn very freely.
