My GC2410 ready for snow (if it ever comes
   / My GC2410 ready for snow (if it ever comes #21
Dale . . just a thought . . The grill guard that comes from Massey that fits the GC products . . Would you have enough clearance to have that on with your plow and use that as a ballast rack ? Its strong, well positioned (high and tight), and usually there is some clearance with plows for angling needs . . and you could add weight in a 12" to 15" inch wide area that would be 125 to 150+ pounds if there would be enough clearance.
I had to take the grill guard off to put on the quick hitch and plow.
It sure looks pretty....but the 1/2" snowfalls haven't even required getting it out of the shed.
   / My GC2410 ready for snow (if it ever comes #22
Could the grill guard mount in front of the quick hitch and still provide clearance for the pliw . . . In other words frame-quick hitch-then grill guard . . .then clearance for plow? If so there is a solution I have in mind.
I can't see any way to mount the grill guard and the quick hitch at the same time. I have an approximately 5x5x15" chunk of steel that weighs 85# that I have been trying to figure out how to sit on top of the quick hitch without welding it on. I can't figure out how to strap it on. If I were to weld it on the weight would make the hitch unmanageable by one person.
   / My GC2410 ready for snow (if it ever comes #24
How about hanging it on with:
2 long threaded eye bolts
2 holes drilled in metal and thread the holes
1 metal rod or pipe that goes thru each eye bolt and suspends weight
Deluxe Option . . Thread each end of rod and add nut on each end keeps rod in place . . . If pipe instead of rod . . Thread inside of pipe and use either a bolt on each end or tractor pin with lynch pin on each end
How is that for not even knowing what it looks like lol ?
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
MASSEY FERGUSON 175 TRACTOR (A57192)
MASSEY FERGUSON...
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
2005 Freightliner M2 106 Dumpster Carrier Truck (A55852)
2005 Freightliner...
John Deere 520M Loader (A53317)
John Deere 520M...
UNUSED FUTURE FTSSJ430J JAW CRUSHER (A57192)
UNUSED FUTURE...
