My new additions (tree shear / puller)
   / My new additions (tree shear / puller) #61
No problem at all. I'm glad to get some reviews about tree pullers. Many out there advertise them but just about none would talk about capacity when paring them to tractors with different lift capacity. I didn't know that offset pulling forces can be an issue.
   / My new additions (tree shear / puller) #62
There is a large profit margin in an attachment such as a Puller. That's why there are sooooo many companies making them. In my area there are 3 different small welding shops making/selling them. Competition is good for the consumer in this case. $1250 will buy a very well built, single swinging jaw puller. I used materials I had onhand, so guesstimating, I've got $500 in materials in mine. Another $75 for construction/paint costs. After building the first one and establishing a pattern, it would take longer for the paint to dry than to build one. :)
Not flaming anyone or any type. Just having a conversation. A Puller is a fantastic addition to anyone's attachment lineup. :)
   / My new additions (tree shear / puller) #63
ovrszd, I noticed. It seems like a simple tool. I do have a 220 welder and I can weld but it's a matter of getting the cut pieces made. I suppose I should give it a shot working off a blank SSQA and go from there but then I'd have to spend time engineering & cutting the pieces.
Question, with the single pinch point, was it sufficient enough to keep the saplings upright when moving around with it? I've got a good number of slim 35-45 footers and I'm worried about them falling over in any direction after they get pulled out of the ground.
   / My new additions (tree shear / puller) #64
Look again at the two pictures I posted of a large cedar tree being carried by the Kubota.
Sometimes it the tree is leaning toward you when you pull it you have to adjust your bite or roll the puller forward to get it balanced away from you.
My Brother's shear had a second clamp that held the trunk about 3ft above the shear. Necessary to control sheared tree because you don't have a firm grip on it. I wouldn't want something like that on a puller. Too slow releasing the tree if something goes bad, like a sideways tip.
As for building one, there's very little that is technical about cutting the pieces. The last thing I did was make the toothed jaw plates. I did that by turning the puller upside down, closing the jaws until parallel, then welded a plate of 3/4" to the bottom of my jaws spanning the gap between them. Then using a cutting torch I cut the teeth by a simple S shaped cut between the jaws.
You'll have to source some solid rod and bushing stock to make the swivels. you can buy that stuff already built or buy the pieces and make it. I had the pins and bushings onhand so that's how I did it. I used 2 short pins. If buying materials I'd suggest one long pin and bushing.
The SSQA part is very easy. Once you get started it would make sense to you.
If you decide to tackle the project start a thread. You'll get a lot of good advice and suggestions about how to build it. Then you just look for the suggestions that match your capability. I've been given some very valuable technical fabrication advice on TBN. Sadly the ones I like best are above my ability to duplicate. :)
   / My new additions (tree shear / puller) #65
Cool. I think I'll try that. Where can I source the hinge materials and what size pins do you think I should I work with. I'd imagine that it's the critical part.
I'll definitely make a thread about it.
   / My new additions (tree shear / puller) #66
My pins are 1.25" simply because that's what I had. The larger the pins, the longer they'll run without slop.
I buy pin stock and bushing stock from my local welding shop. If you decide to try pin/bushing assemblies you might ask your local shop where they get them or if they sell them. Maybe a Google search would find you the materials at a better price, not sure about that.
I've saw some pullers with very large pins and bushings that were obviously purchased sets.
Maybe some of these guys with pullers they purchased can chime in and share the specs on their pullers?
   / My new additions (tree shear / puller) #69
rlgustafson, The puller you got looks quite beefy! What did you pay for yours?
   / My new additions (tree shear / puller) #70
It was about $1400 and free shipping as I was a repeat customer. I bought my 84" dual lid HD grapple from them.
The tree puller is heavy enough to be used on my NH TL100A. Primary use is on my LS XR4046HC.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
