My new bucket teeth
   / My new bucket teeth #31
Bobcat Bucket Teeth
This place was the cheapest I could find. I did find another place that had a much larger selection of bolt on but prices were $12 ea up to $25ea plus.
This company was out of PA, had them in stock. Ordered on a tuesday morning and delivered on a thursday:thumbsup:
We'll see how I like them. But if It turns out that I never take them off, I will get weld on ones next time. Bolting them on took longer than It should have.
I just ordered 8 of these. $76.87 to the front door.
I appreciate the write up.:thumbsup:
Great. You will have to do a write up when you get them and install them.
What kind of tractor or skid loader are you putting them on??
Do you have a way to drill the cutting edge if it is hardened??
   / My new bucket teeth #33
I ordered the teeth on the 9th and they were on my doorstep on the 11th!
They are going on a Kioti DK50.
There are 6 predrilled holes on the cutting edge so I'll just need 6 more for the back holes as well as 4 holes for the other two teeth.
I'm gonna try a 5/8 drill bit. I'll have to enlarge the holes on the teeth and the tractor about 1/16th.
They are too small for 5/8 and too large for 1/2". The are also too small for M16.
I would just use 1/2" bolts and call good.
   / My new bucket teeth #35
I ended up going that route. I tried to take the teeth up to 5/8 and toasted a new bit.
Installed 6 teeth today.
I drilled holes(most of them, my drill fried) to install the other two teeth at either end, at an angle(saw it on my grader's 943, so I copied it).
They aren't perfectly straight because I left my speed square at the house. :mur:
Dont worry about the crooked teeth. Mine are that bad too. Did you see the pics at the beginning??:laughing:
And IIRC I even used a square. But no center drill and the bits walked just a tad. But works just fine.
23013 (A55787)
23013 (A55787)
EPPS Powerhouse Pressure Washer (A55973)
EPPS Powerhouse...
air compressor (A55758)
air compressor...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
