farmstart
Thanks stonypass. How do you like the bush hog. I ran it pretty hard the first couple days and got a lot cut till the shear pin finally gave, or should I say hitch pin..........![]()
I talked to Howse Monday and got the specs for the bolt that is supposed to be in there for the shear pin. Looks like the PO had put a 1/2" hitch pin in place of the 1/2" bolt. Sure makes for easy changes but I cannot find what grade steel is used in hitch pins. If it's stronger than grade 5 that is not good so I am going back with the factory spec of grade 5 bolt for the shear pin.
Boy I know the torment of that. I have a HD. Brush hog with a slip clutch thank god. Other wise I would have had to replace 9 of them last year at least. My torment was running over old electric fence that was left on the ground years ago. Trying to restore old farmland has its torments. Spending hours cutting the wire out that wrapped around the blade shaft. What a PIA. I have a Kodiak brush hog. Tough but I have torn out a couple of places in the back ripped the 1/8 inch steel like paper. I'll have to see if I can have my neighbor weld it up for me.
