My new Yanmar. What is it?...and other question.
   / My new Yanmar. What is it?...and other question. #31
That input seal should be fairly easy to replace compared to the output seal on a brushhog. Mine got a baling band wrapped around it and began leaking about 10 years ago. a couple of top-offs with Lucas, and VOILA!! no mo leaks.
   / My new Yanmar. What is it?...and other question. #32
Sometimes if you can clean the part of the seal that is accessible you can spray it with Brakleen, or equivalent brake parts cleaner, and then with compressed air to expand the seal rubber enough to reseal the shaft and stop the leak.
Cool that you've met Ed & Mike. Shortcuts on autowork? Ah, the magic of Television... Maybe you could talk Ed into starting his new show about tractor refurbishment and have him restore your Yanmar to factory condition?!:D
Haha, I can just imagine Mike having one of his jaunts abroad to buy spares and ending up at Hoye! I actually have one other connection to that show, my friend was featured selling Mike some parts for a Porsche.
Anyway, now I've dazzled you with my celeb connection...
Back to the little Yanmar, probably the last question for a while, is it ok to change gear whilst moving, or should I stop? I've heard you're not supposed to shift while moving in some tractors.
   / My new Yanmar. What is it?...and other question. #34
Depends on whether you have syncrosmash trans or not. Try it at low RPMs first if not sure.
   / My new Yanmar. What is it?...and other question. #35
The F14D is a geared transmission with no syncronization. It should be stopped to shift all gears. The FX14D is a power shift and the power shift can be shifted on the fly but not the range shift.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
