My Sub $100 Cab
/ My Sub $100 Cab #1
jimb1724
Claremont, NH
ck20hst
I finished my improvised cab just in time to go out and snow blow after our first nor'easter....
thanks to the input and ideas from my previous post on this topic, i decided to use 1" pvc pipe and fittings $15, topped off with a half a sheet of osb plywood $7 and a $69 golf cart cover......
not pretty, but it works to keep the blowing snow off ......
/ My Sub $100 Cab #2
Can't beat the price! Looks like it will do the job.
How did you fasten the front to the tractor?
Where did you get the golf cart cover?
/ My Sub $100 Cab
i used 3" hose clamps around the pvc and the brace for the FEL... i also used the hose clamps to attach the back piece to the ROPS... the i used 1" u bolts to tie the plywood to the pvc frame....
the cover came from golfsmith.com it's the cheap model for $69.... next year i might upgrade to the delux model......
/ My Sub $100 Cab
Tig said:
I like it Jim! Something like that may work for me. How is it in the wind?
haven't tried it in high winds yet...... fingers crossed... that will actually happen later today when the snow stops.... winds are gusting right now...
the cover has hooks built in that would attach to the golf cart.... i'm using the same hooks to attach under the operator platform and fenders......
it's certainly not air tight but the main purpose is to keep the blowing snow out....
/ My Sub $100 Cab #6
Yeah, that's what I may need. I don't mind the cold. But keeping the blowing snow out of my face would be nice.
/ My Sub $100 Cab #7
Nice looking setup, anything to keep that blowing snow out of your face is great. Now you just need a little heater. :D
/ My Sub $100 Cab #8
Looking good Jim. I went ahead and bought a Femco weatherbreak and like you I finished putting it on in the earlier snow storm this past week. Still have work to do on it, but it is much nicer than before.
/ My Sub $100 Cab #9
Wayne, me thinks if you could just lower your sunshade a bit...... and put some lexan across the back, you'd have a cab !
/ My Sub $100 Cab #10
be careful with trying the new unit out. Winds are gusting to around 40mph right now at my place, prolly be in your area in a couple hours.
/ My Sub $100 Cab #12
Have to get low profile lights before I can do that. I have a piece of lexan for the back too, just didn't have time to put it on. Will be adding a chute rotation motor then things will be pretty good.
Although it isn't totally closed in it sure is a bunch better than last year.
/ My Sub $100 Cab #13
Do you notice a lot of difference with your femco weather brake? I've been looking into those pretty seriously this year. Seems to me if it could just keep your feet a little warmer it would be well worth it.
/ My Sub $100 Cab #14
Thanks to NY YANKEES FAN posting his setup a few years ago, I'm in my 3rd season with mine. Has held up well in high winds.
BTW fellow Granite Stater's picture was taken last year, thus the lack of snow. Current storm should end in a couple of hours. Then it's play, play oops I mean work, work, work again.
/ My Sub $100 Cab #16
I have only had this on for a few days now, but I think it is really nice and is a lot warmer than not having one at all, which is how I blow or plowed snow for many years. I still have a few things to do to tighten it up a bit, but I believe it is worth what I paid for it. I can actually be out blowing snow for hours and come in and be relatively dry!
Send me a PM and I will provide you with additional information regarding where I purchased it.
/ My Sub $100 Cab #17
I wonder if this would work to keep out the rain too. Just bought prop in Washington and got a Yanmar 336D to work on it but of course it rains a little up there. Checked New York Yankees Fan previous post and looked at Northern Tool site where he got his. Interesting thing is it's lower in price right now but the shipping weight went from 9 lbs. to 15 lbs. Sounds a little funny that weight would increase that much in several years. Anyway other post gave another site Golf Cart Accessories, Golf Cart Parts, Golf Car - The Most Golf Cart Accessories and Golf Cart Parts from Buggies Unlimited that had it for $68.99 which was $16.00 less then Northern Tool. Don't know what they want for shipping has you have to almost place the order by filling out all the order info to get the price, so forget that. I hate it when you have to fill out all that information to just get a shipping quote.
Ralph
/ My Sub $100 Cab #18
Ram,
Yes it will keep the rain out depending on how tight the fit is on your tractor. Seems that rain will always find a place to leak. I have to believe you will be dryer then without the cover for any length of time in the weather.
/ My Sub $100 Cab #19
WayneB,
This is the first time I have seem the Femco unit. In the past I have looked at the likes of the Curtis Cabs etc but they are way too expensive for the amount of time I would need it. The Femco looks like a interesting compromise. I agree that with a few more pieces you almost have an enclosed cab!
Can you tell me (typically) how much does one cost?
Also, it there drilling involved or is it mainly bolt on?
Thanks,
~jim
/ My Sub $100 Cab #20
jambx said:
WayneB,
Thanks,
~jim
I looked at the full cabs (would really like to have one), but just could not afford them. The first thing I purchased was the sunshade top off from Ebay. The thought was to keep the snow off from the seat area, if possible.
As for the Femco unit for my tractor (B-7500) I ended up ordering a unit that was designed to fit a B-7610. The person I bought it from wasn稚 sure if it would fit the B-7500, but I figured if it needed a bit of customizing I might be able to do it. Ended up that it fit fine and there was no drilling required. The kit provided all of the bolts, nuts, and fasteners required to install the weather break. I paid $310 plus shipping for the Femco unit and $212 for the sunshade.
I have purchased a piece of Plexiglas to install on the ROPS and will be doing that shortly, once I get the chute rotating motor assembly completed and installed. Right now I need to be able to reach to the handle of the chute rotator.
Jim I sent you a PM regarding this.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2005 Little Wonder High Output Walk-Behind Blower (A64553)
2005 Little Wonder...
2006 KOMATSU FD80T-8 FORKLIFT (A67148)
2006 KOMATSU...
SHOPBUILT T/A TRAILER (A64278)
SHOPBUILT T/A...
2002 Chevrolet Express 3500 Shuttle Bus (A64194)
2002 Chevrolet...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
