My test of a rubber scraper vs a pipe on the blade edge results
   / My test of a rubber scraper vs a pipe on the blade edge results #11
AND I have tried a chunk of heavy duty PVC pipe on my rear blade cutting edge. I was totally surprised - after being cut/slit lengthwise and slid over the cutting edge, it stayed on, worked great but, unfortunately, did not last long. The gravel driveway was just too abrasive for the PVC pipe.
How long did it last? FYI: there's a big difference in PVC Schedule 40 vs Schedule 80 pipe. Schedule 40 & 80 Pipe Dimensions
   / My test of a rubber scraper vs a pipe on the blade edge results #12
Somewhere here, I think, I read that ABS pipe worked better than PVC.
Bruce
   / My test of a rubber scraper vs a pipe on the blade edge results #13
What is the best way to cut rubber like a stall mat?
I used a stiff straight edge and a razor knife.
I would like to try an osculating saw but I didn't have one at the time.
   / My test of a rubber scraper vs a pipe on the blade edge results #14
I also had no problem using a straightedge and utility/razor knife. If the blade is dragging too much spray a little WD-40 along the cut.
   / My test of a rubber scraper vs a pipe on the blade edge results #15
I buy the cheapest circular saw blade I can find. If they are still usable after cutting stall mats, that's a bonus. Otherwise, i throw them out.
   / My test of a rubber scraper vs a pipe on the blade edge results #16
I have tried both the belting and pipe to keep from plowing the gravel off my driveway and neither has kept me from having to rake gravel off the grass, both have lessened the amount of gravel on the grass. The abs pipe does not last long and neither did the belting. Currently I have a piece of 2 inch metal pipe on and even it is getting pretty worn.
   / My test of a rubber scraper vs a pipe on the blade edge results #17
Over the years I found the best approach is to just keep it really gentle and not dig in at all until the ground is completely frozen. After that you can pretty much do as you please. I learned that the hard way many years back when I did a real nice bank job because my back blade wasn't flat. It took a lot longer to fix than it did to create.
   / My test of a rubber scraper vs a pipe on the blade edge results #18
Utility knife (several passes) cut my horse stall mat just fine.
   / My test of a rubber scraper vs a pipe on the blade edge results #20
I tried plastic pipe and it worked well for a while, until it wore out. I'm going to try horse stall mat next
Giyi Pallet Forks (A53316)
Giyi Pallet Forks...
Tires (A50322)
Tires (A50322)
2002 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2002 POLAR TANK...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
CAT Quick Attach Forks (A47477)
CAT Quick Attach...
