My Trailering Adventure
   / My Trailering Adventure
After reading all the responses so far to my post I thought I'd clarify a little more about my equipment and my mistake. Got plenty of time on my hands right now, this arm is very uncomfortable to say the least - got the cast put on yesterday. It broke the radius bone (the larger of the two that are your forearm) clean in half just before it meets the wrist. My hand is about the size of a baseball mitt.
My main mistake was assuming the grade wasn't too steep to load. If I had thought it was a risky grade I would have moved down the driveway another 150' and everything would have been OK. Had I thought it was too steep and didn't have an option, I would have put it in 4wd and used the 2 excellent tire chocks I always have with me - sawmill oak tie blocks that I cut on an angle and even added rope handles to.
I built the flip-up ramps for my trailer and they each have 2 full-framed channel iron legs under them - no need to block the end of the trailer. The only thing is that if I'm not on level ground the legs may not quite touch the ground or just the opposite - they may not let the ramps go down all the way. In this instance the legs were barely 3/4" - 1" from meeting the pavement but it was just enough to take a little weight off the rear tires of the truck. The tires did not leave the ground - I distinctly remember looking at them as they broke traction. At first I though maybe it had broken the park pawl in the trans. and/or the park brake wasn't tight enough. I never have liked the brakes on my F250 - Ford could have done better, but the wheels were stationary. We haven't had rain here in quite awhile so the driveway had just the slightest bit of dirt/sand/gravel from vehicle traffic on it which made it easy for the tires to skid along.
As far as moving the tractor forward or back off the trailer, don't know even now what might have worked safely, sure didn't have time to think about it while sitting up there, was picking up speed quickly. I think if I had gone forward and stopped the skid with tongue weight it would have launched me off the tractor and over the truck - it sure slammed the tractor into the truck hard when it caught traction and stopped !! Granted I didn't have the park brake on the tractor but it was still in low gear with the engine stopped. As far as backing off the trailer, I was in low range forward and it would have taken too much time to shift to reverse and drive the approx. 8' to get the rear tires back to the pavement - I was at least 2' onto the trailer and my ramps are 6' long (my trailer isn't a dovetail).
I also could have snatched the break-away cable out to lock the trailer brakes before loading - it would have moved maybe 6" before they engaged and all would have been OK too. In fact I had just adjusted & checked operation of the trailer brakes before going to this jobsite a couple days before. I always pull the break-away and turn the wheels by hand to make sure each one is operating, never know when a magnet or wiring is bad. It only takes about 1/4 of a turn of the wheel before mine engage on this trailer.
All in all it was just a costly error in judgement on my part, not faulty equipment or lack of equipment or know-how. I'm glad my little story opened a few eyes - those of you that said you had never considered this scenario. You can bet it will never happen to me again - that rig will be locked-down tighter than a drum before I load/unload again.
   / My Trailering Adventure #22
ultrarunner
Dexter does have this option but I'v never seen one with it.
tom
   / My Trailering Adventure #23
Thanks for the lead... I'm heading overseas and will check it out when I return...
   / My Trailering Adventure #24
Both my flat bed 20' and dump trailers have the Dexter electric brakes. (Not as described in previous thread works like disc brakes.) When I'm in a situations similar to this, I just pull the brake away cord and it sets the brakes on the trailer so one can not move it unless you skid the tires across the ground. When the trailer is loaded, I just reset the brake away and ready to go. The battery backup automatically takes over it the trailer comes disconnected for the towing vehicle. :)
The Gotcha Man
   / My Trailering Adventure #25
Someone may have mentioned this; if so I missed it.
If you have 4WD, engage it and set the parking brake. Then you have front and rear wheel parking brakes.
   / My Trailering Adventure #26
Right you are. I never even thought of that solution or possible way to get around the problem. :)
The Gotcha Man
   / My Trailering Adventure #27
mmmmmm i think some people on the boards might be investing (and useing) a couple of these in the future :D
glad to hear it was only a "minor" incident
might i suggest
wheel chock from Northern Tool + Equipment
   / My Trailering Adventure #28
Wow. That musta made you pucker. I did just reading it. Glad it was not any worse. I am glad to live where I do... I have never had to worry about those issue. Truck driver friend was hauling some tractors with his pickup for us one day and had close one. Went to loader the first tractor and as he drove on, the whole trailer lifted up in the air. He forgot to latch the hitch on the ball. (gooseneck) Luckily, he had enough momentum that is came right back down ON the ball. Sure scared him good.
   / My Trailering Adventure #29
might i suggest
Yep, I found four of them on the back road to the farm on one trip last week. They were all within a mile. of each other on different sides of the road as if they fell off of some vehicle. Now they are attached to the truck and one of the trailers with a hunk of light weight chain and a big TGM stenciled on them. :)
The Gotcha Man
   / My Trailering Adventure #30
Skip that had to be one scary experience. Thanks for sharing, you sure pointed out the potential danger of loading on too much grade to me.
How much do you figure your tractor weighs?
MarkV
MarkV
My tractor with FEL which I almost never take off, and the light duty boxblade I have is just under 7,000 lbs. w/loaded rear tires too. My F250 with normal tools etc. weighs right at 8500, depending on how much fuel is in it and how much I ate the nite before. My 20' trailer scales at exactly 3040 lbs. These weights have all been checked on 4 different scales over time.
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
