My War on Poison Ivy
/ My War on Poison Ivy #81
I've never had very good results spraying poison ivy with stuff like Round Up, but have found that by clearing an area and opening it up to more sun light makes it go away. Around here, it prefers shady areas.
What usually gets me is cutting up wood or picking up some fallen branches. It never fails that a few days afterwards, I get a rash from touching the wood that has some of the oil on it. Goldbond works the best for me on itchy areas or stings. I've tried just about everything out there and nothing works as well. I've also learned that it's different for everybody. My mom gets it real bad and Goldbond doesn't help her at all.
Eddie
/ My War on Poison Ivy #82
My nephew last summer had his dirtbike at our place and got PI. My wife thought hey lets try this and see if it works. Took the kids arm and doused it with some cheap 70 proof rum a friend brought us from Cuba. He had a big patch on his forearm, the next morning he had 2 little pimple type bumps, by the next day he had nothing. He claimed that it stopped itching as soon as the rum was on his arm. If you think about it alcohol dries skin out so it will clean (degrease?) the oily PI off of you and dry out the patch on your body. I assume rubbing alcohol would work too.
/ My War on Poison Ivy #83
DO NOT burn poison ivy, no weed burners, bonfires, nothing. Trust me on this.
/ My War on Poison Ivy #84
I go back and forth on this... Have old neighbor that did that accidently while out camping. Wound up in hospital, resperitory issues.
On the other hand, I have been out on wildfires, and have not had issues; I get poison oak really easily, really bad, with oozing blisters. only issue I have had on the fire line, was picking up hundreds of feet of hose, or cleaning hose/tools back at the station.
Next week, we have Wildland refresher training; we'll be advancing hoselines, cutting fireline etc thru it. I keep all my gear on till it is time to get back on the engine. I wear a long sleeve shirt and gloves while cleaning hose/gear. Then take a cool shower with lots of Technu. Old fashioned home made Lye soap works real well too...
I have been puzzled by the "Dont burn PO/PI" because of this. I certianly do not consiously put it on my burn piles. But there are lots of firefighter out on the firelines each year without issues.
I really don't know an answer...
/ My War on Poison Ivy #85
I don't understand why you can't burn it either. I burn it all the time. The poison is in the oil that is on the surface of the plant. Getting that oil on your skin is what causes the rash. Burning it destroys the oil. The oil does not float around in the smoke once it's burned.
Eddie
/ My War on Poison Ivy #86
A service of the U.S. National Library of Medicine
From the National Institutes of HealthNational Institutes of Health
DO NOT
Do NOT touch skin or clothing that still have the resins.
Do NOT burn poison ivy, oak, or sumac to get rid of it. The resins can be spread via smoke and can cause severe reactions in people who are far downwind.
When to Contact a Medical Professional
Call 911 or go to an emergency room if:
Someone is suffering a severe allergic reaction, such as swelling or difficulty breathing, or has had a severe reaction in the past.
Someone has been exposed to the smoke of a burning plant.
I may not affect you, but it may affect others adversely.
/ My War on Poison Ivy #87
I was surprised to see our goats eat poison ivy like candy. I had bunch of it, and they killed it off.
/ My War on Poison Ivy #88
Eddie
I think if you were in a rural area with no neighbors, I'd burn it, I sure wouldn't sit and breath the smoke!.
/ My War on Poison Ivy #90
Lots of ways to kill it. I am very sensitive to it and have found the best time to attack it is i n the winter when it is dormant - it is not producing the oil near then and although it is not inert it has much less effect.
As a couple of people have mentioned sunlight and goats are very effective natural killers. Sometimes you cannot get sunlight to a spot or you do not want to deal with goats. Other options are:
sprays - I prefer a 2,4-D Amine LV to Roundup but you have to get above it and have it land on the leaves
Cutting it off and then coating the stumps - Tordon is much more effective than Roundup for this. Both need to be applied within 5-10 minutes after cutting
I have had poison oak so high climbing up fence posts that I used my chainsaw and cut it off at the top of the post and it was like a small tree falling off. I did this in the middle of winter and and let it dry very well and then pushed it into a pile and burned it. If you let it dry the oil will turn to more of a resin and the heat of the fire will oxidize it and it will not be a problem. If it is too wet and smokes while burning the oils will not be completely oxidized and then you may have a problem.
/ My War on Poison Ivy #91
We have a friend who had a couple of goats. They devoured poison oak. One was a milk goat though; they believe they got poison oak from drinking the goat milk.
/ My War on Poison Ivy #92
I do not believe that burning oxidizes all of the oil in the PI.
It is more like the nicotine in tobacco, burning the tobacco vaporizes some of the nicotine and burns some of it, which is why smokers smoke. They like to inhale the vaporized nicotine.
Think about what happens in a burn pile. There is fire some places, but a lot of places are hot enough to vaporize components of the material in there and not burn it. Smoke is just unburned particularities and condensed vapors from the material in the burn pile.
Vaporized PI can kill people who are very sensitive. I never burn the Poison Oak we get out here on the left coast. And, I will wait as long as necessary so I do not drive through the smoke of someone else's burn pile. I am very sensitive.
/ My War on Poison Ivy #93
When I bought my place it came with a dozen Greyhound bus sized burn piles all laced with both dead and live poison oak. Most of the land was covered in poison oak. There are laws on the books around here that forbid burning poison oak. But here, there's really no choice, so one by one, I torched the old piles, waiting for a damp day in the winter with little or no wind. Once the fires were lit, I stayed away and out of the smoke. Never had a problem.
Two summers ago a neighbor brought his dozer over and started knocking down scrub oak, manzanita, and huge poison oak vines. That all went into new burn piles, almost forty of them, all bus size. It took all summer, working a few hours most days. That winter we burned, burned and burned some more. Still no problems with smoke because we stayed out of it.
Prior to the dozing, I was trying to pull the plants with the 4-in-1 on the FEL, and lopping shears where I couldn't get the tractor. Needless to say I got PO a couple of times, but eventually developed a routine that has kept me free of it. I always wear gloves, long sleeve shirts, and long pants when working around PO. Also keep the collar tight on my neck, because I've had dust fall down the shirt front and start a rash at my belt line. My belt is nylon with a plastic buckle, and it goes into the washer with the rest of the stuff when I'm done. If I get hit by a plant and notice it, I'll stop whatever I'm doing and rinse off with cold water, which seems to take care of it. I also love to mountain bike, and sometimes you can't avoid PO on narrow trails. In those cases I use water from my pack or bottle to rinse the effected areas, or take a dunk in a stream if there's one nearby. When I get back to the car, again I strip off and put the contaminated clothing in a plastic bag, then it's directly into the washer when it gets home. That keeps the oil from contaminating the clothes hamper or other clothing, or having someone else unwittingly handle the clothes next time they do laundry.
At the end of the work session, I rinse my gloves off at a hose bib, just leaving them on and washing them like I would my hands. They're elk skin, so I leave them in a shady spot to dry and they're usually good to go again in the morning. I also rinse off any tools I've been using, even the tractor, with cold water out of the garden hose. Sometimes I'll use a brush, but mostly just cold water seems to work just fine. Things dry quickly in the sun out here, and I usually don't bother with WD40 or the like. Finally I'll rinse my boots off, and sometimes use a scrub brush on them, again just using cold water. I always finish by rinsing the hose and nozzle off, then my hands one last time. During all of this I imagine that everything I used or worn out in the field is contaminated with PO. I used to work in nuclear power plants, and that was the routine used there to prevent the spread of contamination, so I figure the same will work for PO oil. So if I turn the hose water on with dirty gloves, the faucet handle gets rinsed off and I only touch it with clean hands after that. Same with tools: handle them with dirty gloves when they're dirty, wash the gloves, then the tools, and handle them only with clean hands or gloves after that.
Once my hands are clean I'll go into the laundry room and strip off everything into the washer, taking care not to touch the outside of my clothing with my clean hands. I try to touch the cloth only on the inside, and will pull my hand up into the end of my shirt sleeve to make a little glove I can use to work buttons, belts, and snaps and pull off stubborn clothes. I always keep thinking "dirty to dirty, clean to clean". When I'm standing there in my birthday suit in front of the washer, I run it in a heavy duty mode with regular laundry detergent. Sometimes I'll throw other stuff in there to complete a load, and haven't had any problems yet. But I'm very careful not to let any of the clothing touch the outside parts of the washer, only the inside that sees wash water.
With the wash started, I'll jump into the shower, using cool to warm water and Nutragena soap, mostly because I like the smell, but it seems to do the trick. When I know I've been dosed by a plant, I'll hit those areas with one of those natural tufa type scrubbers with straight soap on it, rinsing with plenty of water and maybe repeating the soap. Avoiding a rash is as easy (or difficult, as the case may be) as keeping the oil off your skin, or failing that, getting it off as quickly as possible.
I also use the same soap on places where I've got a rash, only using the hottest water I can stand. I figure that the hot water will open up the pores in my skin and let the soap get to the oil better. That's just the opposite of what's needed when the oil is freshly applied to the skin, where cold water will keep the pores closed and rinse the oil off before it has a chance to penetrate the skin. The Nutragena treatment dries out the PO in a few days and provides some temporary relief from the itching. That first year I got PO pretty badly a couple of times and my doctor wrote a prescription for Triamcinolone 0.1% cream. It's white and a little goes a long way. I've learned to rub it in until it disappears, otherwise it doesn't do much. Used that way, though, it takes care of the itch and the bumps/blisters go away in just a few days.
That same doctor told me that as I am get more exposure to PO my symptoms will worsen, and that there's no such thing as being able to build up an immunity through repeated exposure. I have a neighbor that swears he eats leaves of the stuff regularly to build up his immunity, but he also says his son is naturally immune and I suspect he is as well. The doc also said that the oil will spread inside the body, and I've seen it myself in my own body. There are injections that will provide an immunity, but my allergist refuses to give them as the antigen frequently leaks from the injection site. That causes a rash on the patient, and frequently on the nurse as well. I wear PJs to bed when I have a rash, a fresh pair each night. That keeps the oil from spreading from the rash sites.
The dozer was the very best remedy for clearing PO off the land, but two years later I'm still getting new sprouts and finding places we missed. Every spring I fill the backpack sprayer with a mix of generic Roundup (I get mine at Tractor Supply) and generic BrushBGone, mixing each with the indicated amount of water to fill the tank. It's a pricy blend, but the Roundup will get in through the leaves, while the BrushBGone goes in through the trunks and stems. Sometimes I'll throw in a spritz of Dawn dish washing detergent, but I've leaned to save that for after the tank is full to avoid creating a foaming mess. Then I just walk around the property spot spraying any plants I run across, and don't worry too much about keeping it off mature trees. I've noticed at least three distinct varieties of the plants around here, but they all respond to the treatment. Even the thicker vines are killed by the brew (the ones here aren't the monsters you guys deal with, but they're over an inch and too big to pull down), but it might take two or three doses. Then I'll hack off the root and pull the plant out of the tree with the 4-in-1 on the FEL, throwing the stuff onto a burn pile for winter disposal.
I always end up missing a few plants, and some sprouts later, so I'll do another hike in a month or so to pick up any stragglers. I've tried dye in the water to help me keep track of where I've sprayed, but so far I haven't found one that gives a strong enough color and doesn't cost a fortune. When I'm done I go through the same decontamination routine outlined above, because no matter how careful I am when I'm walking around I always seem to end up standing on or next to a plant I didn't notice until it was too late.
They say God works in mysterious ways, and I gotta say that between PO and mosquitoes, there's a lot of truth in that. I think I'm finally getting the upper hand on the battle around here, but I don't think I'll ever be able to drop my guard and miss my monthly spray patrols.
2020 Deere 50G (A53317)
2020 Deere 50G...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
12" MINI HYD AUGER (A60430)
12" MINI HYD AUGER...
