Mystery O-ring on FEL piston near bucket?
   / Mystery O-ring on FEL piston near bucket? #1
Sniggle
Jefferson County, WV
2003 Kubota B7800 (new to me @ 435 hours
Soon I will stop making so many new posts, I promise.
I was just looking over my tractor, and I noticed a rubber O-ring that was around the piston shaft between the bucket and the hydraulic piston. I am guessing that it belongs just inside the end of the piston body, and somehow worked its way out.
My first inclination was to gently press it back into the piston main body and hope it stays there (I may help clean the piston shaft?). But I figured I would ask all of you first.
Is this an unusual occurance? Does it have any implications for the life of the hydraulic element? Should I just try to reseat it into the head of the piston body?
Thanks again.
   / Mystery O-ring on FEL piston near bucket? #2
That was placed on the rod before painting, they are usually removed before delivery. Don稚 worry about it. Cut it off. KennyV
Kenny,
Thanks...that makes sense as there is some paint the exterior side. That sucker held on for quite a while in there before popping, almost 450 hours.
I will remove it and get on with work (once it stops raining).
   / Mystery O-ring on FEL piston near bucket? #4
No it's not....it's a spare just in case you have a leak:)
Yea Kenny is correct;)
2021 Bobcat S740 (A53314)
2021 Bobcat S740...
20713 (A55853)
20713 (A55853)
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2007 DRAGON 150...
2014 Freightliner MT55 Box Truck (A55788)
2014 Freightliner...
2018 Kubota U17 (A53314)
2018 Kubota U17...
