Nailing shingles
   / Nailing shingles #11
<font color="red">
What about plywood and paint it with some sealant - like fence paint, driveway sealer or such? </font>
If you have an air compressor, you could use one of the 2-part epoxies that would normally be sprayed into a pick up truck as a bed liner. Rhino-Liner is the most common brand, and you can't buy their branded mix, but you can find other brands of 2-part epoxy that would make a very good roof. The cost to cover the roof would probably be about $150, assuming 2 coats are applied and that the roof is basically the size of 2 or 3 sheets of 4x8 plywood.
A spray on 2 part epoxy will be much better than anything you can roll or brush on. It will be much thicker and more flexible too. I've used it on a couple projects and been very satisfied with the stuff you can buy on Ebay (Rattleguard and Xtremeliner).
   / Nailing shingles #12
<font color="red">
   / Nailing shingles #13
If kids are going to climb on the roof, you have to be concerned using any material that is slippery when wet. I would think that paint or driveway sealer would be very slippery when wet.
   / Nailing shingles #14
   / Nailing shingles #15
Use the 1/2" nails. What are you worried about?
   / Nailing shingles #16
   / Nailing shingles #17
Have you thought about staples? With an air stapler it would be a very easy install.
SimS
   / Nailing shingles #18
SimS
   / Nailing shingles #19
A staple gun works good, you should be able to get one at Home Depot. They use the heavy duty Arrow staples but are used like a hammer, don't need air, and they are a lot faster than nails. I worked for a guy framing houses about 25 years ago and we called them slap guns. Not sure what the real name for them is.
Greg
   / Nailing shingles #20
Greg
2022 New Holland Workmaster 40 Tractor with Loader (A51573)
2022 New Holland...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
New/Unused 250 PVC Safety Traffic Cones (A51573)
New/Unused 250 PVC...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
