Name This Tool!!
/ Name This Tool!! #1
Oleozz
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
Bought it last week, used it today, was just as advertised and then some.
Know what it is?
/ Name This Tool!! #2
We had something like it on the farm I worked on as a kid except it had pointed tips on the bottom. It was used to pick up hay bales and winch them into the hay mow where it would ride down the rail to one end of the barn and trip, dropping the bales for me to stack.
/ Name This Tool!! #3
Why it's a lifter-upper of some sort. Don't know what it is supposed to lift though.
/ Name This Tool!! #4
Flip it upside down, hang it from that 'I' beam in your shop. Hook a come-along or chain fall on the chain to lift heavy items and move them from one side of the shop to the other.
/ Name This Tool!! #5
I beam carrier. You lift the chain then use the rollers to balance the beam as you move into place:D
/ Name This Tool!! #7
I would say it's definitely used to hang and not lift. What are you using it for?
/ Name This Tool!! #8
Too lightly built for an I-beam carrier or even a sling under an I-beam. Maybe a stock holder to work with a saw of some sort. Not height adjustable though. Hmmm...
/ Name This Tool!! #9
I may be wrong but I think it is used to lift dual wheels on and off of large farm tractors. The rollers allow you to move the wheel enough to get bolts started.
Dan
/ Name This Tool!! #10
Looks a little light for that, I don't think it is made to lift more than 2-300#. The top chain looks to be 3/16" G30 welded link chain which IIRC has a WLL of 400# and the arms look pretty flimsy.
Aaron Z
/ Name This Tool!! #11
Do we get a clue?????
/ Name This Tool!! #12
I like the WHEELIFTERSPINNERHOLDERTIRECHANGER device the best! That's my opinion and I'm sticking to it!:D
/ Name This Tool!!
Sorry I didn't get back sooner, yes Dan and FWJ named it correctly.
I had inquired on another site about them but nobody seemed to know much about it or had never used one. When it arrived I wasn't sure it could lift much, let alone a ton.
I wished I would have had the camera when we added the two tires, it was a slick operation. I operated the FEL, a friend attached the tire changer to the tire, I drove the loader tractor to the 1066 with the wheel hanging there and he manuevered it into place, spun the tire so the holes would line up and put the studs in. Each tire took about 10 minutes for the entire process. I'm guessing each tire with rims and fluid might have weighed 850 lbs, but that is just a guess. There was no heavy lifting or straining to get the tire in place.
My friend, a life time farmer, was impressed. He was sure it was not going to work but when we were finished he said, "Darn, that thing did the job, didn't it!".
/ Name This Tool!!
Should have mentioned that the correct name is Bierman EZ Dual Tire Changer. He has a web site with a neat video of a man changing some tires close to the size of the ones we were fooling with. I paid about $345 plus shipping for it and I think, since using it, well worth the money.
Last fall I tried to get a local tractor tire seller to put on the duals, he took one look at the tractor and told me it wasn't worth the money for him to fool with it.
/ Name This Tool!! #17
I guess that's the right answer, I was gonna say that it looked home brewed, some kind of light duty beam trolley.
EZ Dual Changer | Bierman Sales LLC :: 712.324.1930
Still it looks light duty for some of those large wheels, especially the chains.
JB.
i think the pic makes the scale misleading. I have a feeling its like 1/4x4" alumimum channel. per the website those are 5" wheels on the bottom. So the idea that its 5/16 or 3/8 chain on the top would be right.
/ Name This Tool!!
The pic is misleading, heavy duty enough, as far as I can tell. Since you are lifting straight up there is no bending or twisting on the arms. Here is a pic of the tires that we changed. They did have calcium chloride in plus quite a bit of weight for the rims.
/ Name This Tool!! #19
Were you wearing a blue sport coat and khaki pants when you changed the tire....?
/ Name This Tool!!
Not quite Swines, but I was wondering why the guy was dressed like he was heading to church.:)
JOHN BLUE 1000 GALLON ALUMINUM TANK (A63290)
JOHN BLUE 1000...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2001 International 4700 Dump Truck (A64047)
2001 International...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2015 Ford F-250 Lariat (A62180)
2015 Ford F-250...
2017 Frontier FM1015R Flex Wing Finish Mower (A63116)
2017 Frontier...
