Nearly went over.
   / Nearly went over.
And not many talk like Paul Hogan or Steve Irwin come to that, I used to travel to the USA 3-5 times a year for work and never encountered any language difficulties, terminologies at times, I assumed that was reserved for the movies.
Then, I only ever travelled to NY, Boston and Colorado.
   / Nearly went over. #72
I believe it is against the rules to go disparaging another member in posts making those so doing being the ones who should be banned if any.
Yep. Most of us have other posters we skip over or have on ignore. This is not a formal writing forum. If it was most would have been expelled by now.
Quityerbitchin about (removed)s commenting style. If you dont like it just scroll on by.
   / Nearly went over. #73
Yeah I posted a vid of me lifting the rear wheels in a big way trying to dig out a bamboo. Glad some of these folks haven't seen it or I would be roasted. As for (removed). Keep it up buddy. I find a lot of your posting very informative. I did well in English at school about 57 years ago and I have no problem understanding (removed). I quite enjoy his dialect. It may confuse real aliens if they come down though. :)
   / Nearly went over. #74
If it wasn't completely FAKE, I doubt anyone would care.
It's the fake, put on "persona" that folks (myself included) dislike.
Most people can spot frauds, especially when they so consistently tip their hands and display their "put on" antics like this guy does.
There's no reason to be fraudulent here on TBN. How are you supposed to take anything this guy says seriously when you know every word he's typing is a "put on"?
   / Nearly went over. #75
Right on.
For some reason, this "persona" only started halfway through his participation on TBN. Before that, it was easy to read and understand.
   / Nearly went over. #76
   / Nearly went over. #77
   / Nearly went over. #78
No disrespect intended, just a strange vernacular transition over a ten year span.
Cajun est avant tout un dérivé français.
   / Nearly went over. #79
Filled tires don't do much for lifting. You need weight on the 3 point.
As others have pointed out, filled tires do indeed provide stability, but they don't move the entire system's center of mass far enough back, so the entire FEL load is still being carried by the front axle.
By hanging a big weight off the back of the tractor, you can actually unweight the front axle completely (wheely time, do not advise); ideally there's enough weight far enough back behind the tractor that the front axle has "enough" weight to allow steering and traction (and possibly stopping) but not so much that the rears are too light or the front axle gets damaged.
   / Nearly went over. #80
Rarely use the brakes as I find backing off the HST almost launches you over the steering wheel, when I started tipping nothing was in my favour, loader high to pick up loops, trailer high putting it up a bit more and one front wheel in a bit of a dip whic I hadn't noticed causing me to lose some personal ballast shortly after the event.
As for (removed), i won't launch an attack and can generally decipher his posts, informative most of the time with a few diversions but I think most of us can claim priors for that, if you want language challenges, go to the UK, a 25 mile drive can change the dialect and interpretations of common words, a compliment in one town can be an insult in another.
Loops probably make it convenient to pick, but makes your loader and center of gravity high, and you experienced the results. Is it possible to lift sacks with forks from bottom?
As for (removed), I can’t understand 50% of what he’s trying to say, the rest is ok I guess, but it’s just easier to skip over than putting in the effort trying to decipher. Plus I had a grandfather that died at the Siege of Louisbourg (1758) kicking those Arcadians out of Nova Scotia down into the swamps. So hearing those marbled mouth echos kind of hits a sensitive spot, though it might be time to let the grudge go?
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
Case Maxxum 140 (A50120)
Case Maxxum 140...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
2010 American LaFrance Condor MRL Long Line Tri-Axle Thermoplastic Striping Truck (A52377)
2010 American...
