need a grill guard
   / need a grill guard #1
h10doc
Collierville,TN
Tc45D
Is there a after market grill guard for a tc45d. I got a little to close to the trailer and killed my light assy. So were can I get a guard to stop this from happen again?
   / need a grill guard #3
$25.00 in steel and a welder can produce some fantastic results. Two hundred dollars is alot of money for three pieces of pipe and a couple flat pieces of steel. There are alot of examples on this forum. Good luck.
do you have any plans for a guard?
   / need a grill guard #5
Not sure what the 45 front looks like.. byut my 1920 had a small bumper flange.. i buzzed a square bumper/guard made from angle iron and perfec metal.. hit it with some blue paint and bolted it to pre-existing holes in the small OEM bumper.. Worked great. Looked so good that when i traded it back to the dealer and offered to remove it as it was non-oem.. owner of the dealership said to leave it on.. it was a good addition.. etc.
Soundguy
   / need a grill guard #6
I looked at the New Holland Grille Guard and I figured all I would end up doing was to bend it into my grille with the 55DA. It just didn't look sturdy enough so I built my own. It does take some time, but the cost is minimal. Attached are pics of the one I built before and after paint.
   / need a grill guard #7
Osconda that's a nicely built grill guard. Looks like it hinges forward to lift the hood, how does it lock in the up position?
   / need a grill guard #8
Pineridge,
In the picture shown with the guard painted you can see two bolts closest to the grille. I have since replaced these with hitch pins. I pull the pins and hinge it forward to open the hood. When I raise it back up I reinstall the 1/2" pins.
I laid out the guard so it would more or less follow the sweep of the front end. I used some foam board (left over wall insulation) to make the pattern for the uprights (1/2" plate). I figured out how tall I wanted the guard to be then started trimming the foam to follow the sweep of the hood. I tried using cardboard but it was too hard to work with.
It would have been nice to have a plasma cutter to cut out the uprights from the plate steel but I resorted to the grinder to clean up the cuts instead.
The brackets the guard is attached are welded directly to the tractor. I was going to drill holes through the brackets to bolt it on instead but drilling the four holes in 1/2" plate meant I was going to have to buy a big drill bit and I was going the cheap route.
   / need a grill guard #9
Mike, I figure we paid $50 for the grill-guard and $150 for the snazzy latch mechanism.:rolleyes: Heck! The grease zerk on it was worth at least $25 just by itself.:rolleyes:
Seriously, even if the materials only cost me $50, I would not go through the trouble of design, layout, cutting, welding and painting a grill guard for the $200 I paid for it. It has saved my high-$$$ hood many times.:eek:
   / need a grill guard #10
Nice work, I am jealous.
Bob
3in Poly Pipe (A49461)
DOOSAN G90 GENERATOR (A50854)
DOOSAN G90...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
Unused 2025 CFG XZ20R Mini Excavator (A49461)
Unused 2025 CFG...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
