Need a Plow Share
/ Need a Plow Share #1
captaincrab55
Maryland
1715 Ford & many more
I need a plow share for a 3 point 1 bottom plow that I bought on ebay several years back... I couldn't find any markings on the plow frame, but found "Made in Brazil" on the Moldboard.. When I bought the plow Tractor Supply carried many types of shares and other wear parts. All of the TS stores close to me are a order only store for plow shares. Not having a manufacture name makes a simple order complicated... Just wondering if someone can chime in with a user friendly site or advice that may be able to identify my plow....
Thanks, Tom
/ Need a Plow Share #2
A pic or two will get you started on right path.
Boone
1 Timothy 2:5
/ Need a Plow Share
A few pictures....
/ Need a Plow Share #4
Measure between moldboard and share,that plow came in 12"or 14",m-board and share.I have the mp-114 sold by Worksaver.com(14").If 14" the part# from Worksaver is 2503290.Go to their site and you will see it.On their site go to product line,then discontued products.Also if you to Cheinc.net,you will see same plow,but they dont list their #s but they have pics of 12/14" plows.
As you can tell that plow has been painted over.I believe they were made or sold by originally by World Agritech Corp. out of Ohio,also known as International(not to be confused w-IH).
That part is pretty common.You should find easily with above mention companys or Agi-Supply or a site member like Ken Sweet.com.
If price quotes are in same ballpark,always good too buy from TBN family members IMHO.Please forgive my lousy pics my plow behind abunch of stuff with boom pole on top,and tractor in front in garage.
Boone
2 Corinthians 2:5
/ Need a Plow Share
Thanks BB, I have the 14" plow...
/ Need a Plow Share #6
Also BTW I could be wrong but in your pic#2 I only see 1 hole.Which tells me possibly at one time someone cut beam short, too mount on BX type tractor.Therefore you cant mount coulter wheel bar(u-bolts).Unless you drill hole behind existing hole and c-wheel has enough clearance from plow frame, if you were planning on using one in future.Of course this does not mean you cant use plow.
Boone
/ Need a Plow Share
Boone
I just saw where the beam was cut in the middle of the hole... If I decide to go with a coulter, there would be a need to weld a piece back on....
I just figure out that I got the plow 8 years ago for less then $100 and it had a new share..... They wanted $85 for a cub plow share back then... I needed a new cub share every 3 or 4 years. I get double the life out of this type of share...
Again Thanks BB,
Tom
/ Need a Plow Share
Boone
Here's a close up shot of the beam, where it was cut off before I bought it...
/ Need a Plow Share
I got my new Plow Share and here's a few pictures..
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
