Need a waterproof clock for dash on open station
   / Need a waterproof clock for dash on open station #1
JCoastie
Platinum Member
Coastal AL
LS MT240HE
I'm looking for a clock for the dash on my open station tractor.
I checked out amazon, and other than the little quarter size stick on clocks I'm not finding much. I'd go with those if they were a little bigger so I could read them.
Ideally it strikes a balance of thin enough not to look ridiculous but large enough to see at a glance.
Anyone have a good solution they've actually used?
   / Need a waterproof clock for dash on open station #4
I have an old Casio wrist watch that i took the bands off and just tywrapped it to the side fender handle.
   / Need a waterproof clock for dash on open station #5
I have a wrist watch with a velcro strap wrapped around the handhold of the Kubota. Had it the same place on the JDs.
I might have a wrist watch from a couple decades ago in a drawer somewhere, might give that a try.
   / Need a waterproof clock for dash on open station #7
Try “marine clock” 52mm. That should get you marine rated 2-1/16-inch clocks, on just about any of the online vendor sites, or search engines.
if I was looking for anything to mount on my open cab, I’d put marine in the search, or IP66. Marine results in IPX5 or better water-resistance.
IP is Intrusion Prevention, the first number is resistance to solids, and the second number is water resistance. #5 survives a 1/4-inch jet of water from any direction with out damage. #6 a half inch jet of water.
An IP66 rating means is dustproof, and survives the 1/2 inch terms of water from any direction.
This page gives a good breakdown of what the different ratings mean: https://www.dsmt.com/resources/ip-rating-chart/.
   / Need a waterproof clock for dash on open station #9
I just check my wrist watch. However - if I wanted one - Jigs_n_fixtures makes an excellent recommendation. Go with a "marine clock".
   / Need a waterproof clock for dash on open station #10
Ive used autometer gauges drill hole sits in flush and nice OR use one of their gauge pods. Summit racing or jegs has a nice assortment
1998 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A52707)
1998 BOMAG...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
ITEM LOCATION (A53084)
