Need Advice on 6,000 Acres and 150 Miles of Piles to clear
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #21
Man still the thought of having to buy big mulchers and maintain them would scare me to death. I know it's the way to go, but will the income out weigh the outcome?
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #22
Why is burning not allowed? I can understand large areas, but it seems that if it is done in small scattered areas it should be OK. Is it because of the environmental/carbon/CO2 issue? If so, I did not think the rules were that tight down there. Heck...up north, (Alaska, etc), they let fires burn themselves out and they will go on all summer, covering hundreds of square miles.
The ash would be good for the fields, too.
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #23
Rather than dozing and piling the debris....
Perhaps you should have dozed it to take out the stumps.
Then followed it with a large hog/mulcher.
http://www.fecon.com/images/pdf/literature/products/2/Bull-Hog-(PTO)-50.pdf
Then you could have left the chips in place.
Of course, for grass, you might have been able to mulch the trees in place, without pushing them out with the dozer then broadcast planted the grass/forage, although you would have to repeatedly run the brush/flail mower over them for a few years to keep them down.
The problem with the piles is that it will be difficult to just run a hog over the piles, and you still won't get the benefit of the mulch in the fields.
With the piles, you'll likely choose to pull the piles apart and grind the debris. But, done right, you should be able to have saleable chips, perhaps even some paper quality chips.
As far as burning, I don't know the local rules and regulations. Certainly SMOG is a major issue around here. There may be some future changes, but most of the field burning has been stopped, and I think the government slash burning may be curtailed somewhat too. Rotting wood, of course, still produces CO[sub]2[/sub], although not as quickly as a fire. It should also add nutrients to the soil without scorching any of the clays.
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #24
Greetings and Salutations,
A tracked shredder will work for the small trees BUT there is an
easy fix for your problem since you have iron and are
looking for some serious shredding power.
Please visit Morbark, Inc. and chat with the folks at Morbark as they have
been in the serious wood destruction business for many years making
wood chips and grinding bark, WOOF, HAHA SORRY could not resist its late etc.
DO you have a group of wood cutters that can cut the trees first and then you
can dig out the stumps with the dozers to then feed the tub grinder?
The Morbark folks can help you very quickly and they also have access to a
large used machine inventory as well.
All you may need is a very large tub grinder for the stumps and a big wood chipper for the logs.
I have no affiliation with Morbark.
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #25
After seeing what Leonz said, I guess a tracked whole tree chipper and a 600 HP tracked mulcher would work, but either way you go that is going to be a huge investment
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #26
Would probably be cheaper to ask to have the regulations changed so you can burn it.
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #28
Pile up around each plot then let set. Now you have each plot fenced in.
   / Need Advice on 6,000 Acres and 150 Miles of Piles to clear #30
Why not chip it and transport it in one swing with this:
Scania R620 8x4 - BRUKS Mobile Chipper ,Sweden - YouTube
Nice setup. It would be great for following around logging operations and picking up a few small slash piles. However, in this case, one would need a fleet of the trucks, so it would be much better to leave the chipper in the field, and only transport the trucks back and forth to whoever is buying the hog fuel & chips.
One might want to also have a chipper capable of stripping the bark and separating the high quality paper chips from the larger trees if there is enough.
2015 DODGE RAM...
Land Honor Rock Bucket (A50514)
Land Honor Rock...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
International 720 6-Bottom Plow (A52128)
International 720...
Orthman 9300 4 row cultivator (A52128)
Orthman 9300 4 row...
