Need bigtime help on trailer decision
   / Need bigtime help on trailer decision #31
I wish the world was black & white like the manuals you are reading. I have done what you are doing & I would go with a gooseneck & at least a 30' lenght. As for what I hauled was a M5400 8' disk & 8' notill drill & some times a 500 gal tank & sprayer with atv instead of the disk. All pulled with a dodge 2500 diesel, which did fine with it over all. Now that I have a one ton dually I would say no issues ever other than mud. Most of the habitat guys in this area use 60-80hp tractors & notill drills with RTV spray rigs on the front of the trailer. Most of them use F350 4x4 drw standard cabs, with 30' or 35' trailers, that have 2 12k axles.
Remeber when doing this stuff you will always need more than can fit on a semi, even though all you have is a truck, best of luck try your truck with the biggest trailer in the budget & upgrade trucks next year if you have to.
   / Need bigtime help on trailer decision #32
Just a quick thought: you can ditch that class 3 reciever and get the class 5 for less than the weight distribution hitch, then you are good to tow any trailer within that weight class. You dont need a WDH, just load the trailer correctly. That means, don't shove everything up to the front until your bumper is dragging the ground.
   / Need bigtime help on trailer decision #33
LabLuvR said:
FarmWithJunk,
I was guessing to the high side. Thanks for the more accurate numbers. Was I right on the 6' chisel plow at 1,000lbs and the six foot disc weighing 1,000lbs.?
Maybe, maybe not. You'll find a few 6' mounted disc's that weigh less, many that weigh more. As far as a "chisel plow", that depends on what you refer to as a chisel plow. If we're talking a field cultivator maybe a good bit less. a TRUE chisel plow, possibly a LOT more. 1000lb should be a good average though.
   / Need bigtime help on trailer decision #34
LabLuvR said:
I have the extended cab 4x4. Thanks to all for your replys! Quite an education here.
I figured it had to be a ext. or crew cab. I don't think you can get a short bed reg. cab.
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
John Deere 3032E with loader and Box Blade (A55302)
John Deere 3032E...
2008 Freightliner B2 School Bus (A55852)
2008 Freightliner...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
