Need bigtime help on trailer decision
   / Need bigtime help on trailer decision #31
I wish the world was black & white like the manuals you are reading. I have done what you are doing & I would go with a gooseneck & at least a 30' lenght. As for what I hauled was a M5400 8' disk & 8' notill drill & some times a 500 gal tank & sprayer with atv instead of the disk. All pulled with a dodge 2500 diesel, which did fine with it over all. Now that I have a one ton dually I would say no issues ever other than mud. Most of the habitat guys in this area use 60-80hp tractors & notill drills with RTV spray rigs on the front of the trailer. Most of them use F350 4x4 drw standard cabs, with 30' or 35' trailers, that have 2 12k axles.
Remeber when doing this stuff you will always need more than can fit on a semi, even though all you have is a truck, best of luck try your truck with the biggest trailer in the budget & upgrade trucks next year if you have to.
   / Need bigtime help on trailer decision #32
Just a quick thought: you can ditch that class 3 reciever and get the class 5 for less than the weight distribution hitch, then you are good to tow any trailer within that weight class. You dont need a WDH, just load the trailer correctly. That means, don't shove everything up to the front until your bumper is dragging the ground.
   / Need bigtime help on trailer decision #33
LabLuvR said:
FarmWithJunk,
I was guessing to the high side. Thanks for the more accurate numbers. Was I right on the 6' chisel plow at 1,000lbs and the six foot disc weighing 1,000lbs.?
Maybe, maybe not. You'll find a few 6' mounted disc's that weigh less, many that weigh more. As far as a "chisel plow", that depends on what you refer to as a chisel plow. If we're talking a field cultivator maybe a good bit less. a TRUE chisel plow, possibly a LOT more. 1000lb should be a good average though.
   / Need bigtime help on trailer decision #34
LabLuvR said:
I have the extended cab 4x4. Thanks to all for your replys! Quite an education here.
I figured it had to be a ext. or crew cab. I don't think you can get a short bed reg. cab.
2021 KOMATSU D71PX-24 CRAWLER DOZER (A52707)
2021 KOMATSU...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
UNUSED EXCAVATOR BUCKET MAILBOX (A52706)
UNUSED EXCAVATOR...
Toro Mower (A50324)
Toro Mower (A50324)
