Need help adjusting offset disk
/ Need help adjusting offset disk #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have a John Deere offset 8' disk. Some may remember it from my restoration project. Anyway, It pulls great and cuts great. However, the disk on the far right front will roll dirt out farther than the rear rt disk can catch and bring back in. Also, it will leave a furrow where the front rt disk travels. On a large field this is not a problem, however, I am disking fire lanes, trailes and around large fields and dont want to hollow out a trail over time. I just want to disk the dirt, leaving the same amount there was before the pass. Even though I completely disassembled the disk and put it back together, I set it exactly like it was when I got it (front and rear gang placement with respect to the frame) I will admit, that the previous owner had a smaller blade on the front rt position. Guess I know why now. I want this thing to work properly, as it was intended so I want to do the necessary adjustment.
1) Should I put the smaller blade back?
2) Should I move the entire front gang to the rt?
)This is my first non 3 pt disk so any and all advice is welcomed.
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
SCAN TO RECEIVE TEXT UPDATES (A65056)
SCAN TO RECEIVE...
2019 WESTERN STAR 4900EX SLEEPER TRUCK (A67714)
2019 WESTERN STAR...
2017 Peterbilt 320 New Way 20ASL 20yd. Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
NEW HOLLAND T4020 TRACTOR (A65057)
NEW HOLLAND T4020...
