Need help deciding.. JD 1050 or JD 4300?
   / Need help deciding.. JD 1050 or JD 4300? #1
BB_TX
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
I have a 950, next smaller to the 1050. The 1050 has a turbo diesel engine. They were made from 1980 to 1988. I did not think the 1050 came with hydro option. I am pretty sure they were all gear drive. All the x50 series JDs are good solid tractors. But it may also be a little large for only 2 acres.
   / Need help deciding.. JD 1050 or JD 4300? #2
Yes, the difference between the 950 1050 was the turbo to up the HP. They were made by Yanmar. You are also correct that the 1050 did not come in a hydro version. The first compact hydros JD came out with were the 655 755 855 955. Is your question that the 950 1050 might be to big for two acres?
OK, something strange happened here. Someone had a post inquiring about the choosing between a 1050 and a 4300. I replied. Now the original post is gone and only the replies are left.
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2013 RAM 4500 (A50323)
2022 BOBCAT S64 COMPACT SKID STEER LOADER (A53473)
2022 BOBCAT S64...
