Need Help identifying Deere 750B Dozer Part
   / Need Help identifying Deere 750B Dozer Part #1
Tanamera
Gordonville, Texas
2008 Kubota MX5100 (Gear) LA 844 FEL, 1952 Ford 8N, 1988 John Deere 750B Crawler Dozer
I think I finally found the hydraulic fluid leak on the 750B I recently purchased. This appears to be some type of spin-on filter housing. Can anyone tell me what this is? I am hoping there is an "O" Ring that has failed. It is located at the right rear of the bulldozer.
Thanks
Here is a wider-angle view so you can see where the part is on the dozer.
   / Need Help identifying Deere 750B Dozer Part #3
I hired a guy that had just become the proud owner of one of these. One hose after another blew! After he was done my project, I understand the blowouts continued. Finally, I understand one of the hydrostat motors failed, leaving the machine sitting and abandoned in his yard!
Are these machines a lemon of sorts?
Hopefully not. Have done many hours of work and have blown only one hose.
Have any idea what the part is?
   / Need Help identifying Deere 750B Dozer Part #6
I don't know anything about these critters. Just a wild guess. First impression is its a filter and if not that a second guess would be an accumulator.
   / Need Help identifying Deere 750B Dozer Part #7
the transmission oil filter looks to be the only element type filter on the 750B
   / Need Help identifying Deere 750B Dozer Part #8
Sure does LOOK like a filter. You tried to see if it would spin off ?
I talked to John Deere and the transmission filter they show is a straight spin-on filter. This one looks more like a housing and the schematic that "joecdeere" posted looks like an element under a housing. i just wanted to make sure what I was working on.
Anybody replaced one of these?
Woods 3180 Batwing Mower (A59814)
Woods 3180 Batwing...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
