Need Help!!! Where to buy BSP Banjo hose assembly?
   / Need Help!!! Where to buy BSP Banjo hose assembly? #11
hazmat said:
I need to re plumb my CCM toplink cylinder. I tweaked the banjo fittings when it made contact with my toolbox:eek: and quick hitch:mad: . My local guy doesn't have the stuff in stock.
Being the heart of hay season, CCM hasn't been much help (I understand that they need to keep the farmers up and running). In the meantime I want my toplink back.
So my workaround plan is to procure 2 new hoses, BSP banjo on one end, 1/2 NPT male on the other for my quick connects.
Problem is I can't seem to locate anyone with BSP banjo fittings. Just spent 1/2 hour looking thru parker's catalog, they have metric banjo, but not BSP. A google search of BSP Banjo turns up many European & Asian links, but nothing in the US.
Oh and due to clearance issues, I want to go straight to the banjo fitting, not a BSP to X adapter and a 90 fitting.
Please help.
Hazmat,
If I understand correctly, by doing what you say, you will take the DPOCV out of play then, right? If that is the case, a possible intermittent solution would be to get a US banjo fitting, as long as the hole in the banjo accepts the BSPP banjo bolt. The sealing is done with those two copper washers. So the hole could be slightly larger than the normal BSPP banjo bolt hole and it would work fine.
Another temporary solution is to get hoses with BSPT threads and use lots of teflon tape to make it seal in the BSPP threads, but I'm not so sure the will be good engagement because of the difference in taper and straight. So suggestion above is a better solution.
TAKEUCHI TB240 EXCAVATOR (A52705)
TAKEUCHI TB240...
2006 Patten Co Inflatable Boat and Trailer (A55758)
2006 Patten Co...
Case 1020 25ft Draper Head (A55301)
Case 1020 25ft...
2021 JLG T350 PORTABLE ELECTRIC SCISSOR LIFT (A52705)
2021 JLG T350...
2008 Ford Focus Sedan (A55758)
2008 Ford Focus...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
