Need help with clear coat paint removal
   / Need help with clear coat paint removal #1
Keoke
northern calif.
JD-970
Hi folks, I need advice on how to remove the peeling clear coat from my JD 970's grill top (around the emblem) without damaging the underlying green plastic which has good color. The plastic under the peeling clear coat is in good shape so I want to take off the peeling clear coat and let it go at that.
Any ideas would be most welcome here.
thanks again,
   / Need help with clear coat paint removal #2
Klean Strip makes a paint stripper for just base clear paints. Supposed to leave primers intact. You might check the can for plastic use. Called "Peeler."
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
