Need help with clear coat paint removal
   / Need help with clear coat paint removal #1
Keoke
northern calif.
JD-970
Hi folks, I need advice on how to remove the peeling clear coat from my JD 970's grill top (around the emblem) without damaging the underlying green plastic which has good color. The plastic under the peeling clear coat is in good shape so I want to take off the peeling clear coat and let it go at that.
Any ideas would be most welcome here.
thanks again,
   / Need help with clear coat paint removal #2
Klean Strip makes a paint stripper for just base clear paints. Supposed to leave primers intact. You might check the can for plastic use. Called "Peeler."
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
