Need help with clear coat paint removal
   / Need help with clear coat paint removal #1
Keoke
northern calif.
JD-970
Hi folks, I need advice on how to remove the peeling clear coat from my JD 970's grill top (around the emblem) without damaging the underlying green plastic which has good color. The plastic under the peeling clear coat is in good shape so I want to take off the peeling clear coat and let it go at that.
Any ideas would be most welcome here.
thanks again,
   / Need help with clear coat paint removal #2
Klean Strip makes a paint stripper for just base clear paints. Supposed to leave primers intact. You might check the can for plastic use. Called "Peeler."
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
MINI DUMPER SDLD25 (A55745)
MINI DUMPER SDLD25...
2014 MACK CHU613 DAYCAB (A55745)
2014 MACK CHU613...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A55745)
2005 PETERBILT 379...
