Need help with John Deere 4520 Dash Symbols
   / Need help with John Deere 4520 Dash Symbols #11
Just some extra info. My dealer called the #1 switch "Load Match" It matches your ground speed with the load on the engine/ so you cannot stall out the tractor with this switch engaged. To much load on the motor and it slows up your ground speed. I always leave it engaged. There is no mid PTO because there is no lever, door side of control station. No 3rd SCV because there is no lever on seat side of control station, unless that is now electronic thru the loader joy stick. #6 is the rear work light. Somebody correct me if I am wrong.
Yes, I got #1 wrong. Had the old 10 series in my brain. Load Match is correct not roll out like I posted. Since it has the auto hydro function it will be later than a 2011 unit so no mechanical 3rd scv but eh controlled.
I didn't realize that a mechanical scv wasn't available in post 2011 units.
Thanks for all the info.
   / Need help with John Deere 4520 Dash Symbols #13
That is true on cabbed models. With open station units (post 2011), you can have 1 electro hydraulic on the joystick, and 2 mechanical, lever controlled SCV's mounted on the ROPs
2018 Ford F-150 4X4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2007 Sterling L9500 National Crane 1800 40 Ton Tri Axle Telescopic Boom Crane Truck (A55973)
2007 Sterling...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
