Need help with John Deere 4520 Dash Symbols
   / Need help with John Deere 4520 Dash Symbols #11
Just some extra info. My dealer called the #1 switch "Load Match" It matches your ground speed with the load on the engine/ so you cannot stall out the tractor with this switch engaged. To much load on the motor and it slows up your ground speed. I always leave it engaged. There is no mid PTO because there is no lever, door side of control station. No 3rd SCV because there is no lever on seat side of control station, unless that is now electronic thru the loader joy stick. #6 is the rear work light. Somebody correct me if I am wrong.
Yes, I got #1 wrong. Had the old 10 series in my brain. Load Match is correct not roll out like I posted. Since it has the auto hydro function it will be later than a 2011 unit so no mechanical 3rd scv but eh controlled.
I didn't realize that a mechanical scv wasn't available in post 2011 units.
Thanks for all the info.
   / Need help with John Deere 4520 Dash Symbols #13
That is true on cabbed models. With open station units (post 2011), you can have 1 electro hydraulic on the joystick, and 2 mechanical, lever controlled SCV's mounted on the ROPs
JOHN DEERE 9 SHANK CHISEL PLOW (A52708)
JOHN DEERE 9 SHANK...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A55973)
2015 Kenworth T880...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2007 Chevrolet Silverado 1500 Pickup Truck (A55973)
2007 Chevrolet...
