Need info for 3-pt on a 990
   / Need info for 3-pt on a 990 #11
"The only other consideration would be - are they heavy-duty enough? Something that fits on my 9N would maybe last 30 minutes on your 990!!! :eek:"
Actually, the Ford 8N was able to handle a Funk V8 conversion with pretty much the same rear hardware as the 9N, so I would NOT count on them only lasting 30 minutes. I have had three 8N's here and let's just saythey were STELLAR performers with ALL the demands I paced on them, and they were extensive. YMMV, IMHO.
Ironwood
   / Need info for 3-pt on a 990 #12
Thanks, I really appreciate you posting these. Good pics.
What year is your tractor? Pre s/n 691474?
Edit to add: From looking a parts diagram it looks like you have the older style turnbuckles on the sway chains.
JP I posted these on GTT for you as well. Here are the pictures on my draft links. They look very similar to Sal64's but mine as you know are of the later s/n units. https://plus.google.com/photos/1160...s/5850945316074369377?authkey=CMei0t_W2oDZ5wE
Below are the JD parts in PDF for these. I am wondering if they are almost exactly the same?
View attachment 990 Draft links and supports.pdf
View attachment 990 lift links.pdf
Rob
Rob, thanks for taking the time to get those photos and post them. Very helpful.
It looks like the lift link attachment is just off the midpoint of the draft links, away from the tractor end, maybe 3/4"?
Any idea what the other hole in the draft links are for -- the one between the lift link and tractor end?
   / Need info for 3-pt on a 990 #14
I have no idea apart from the fact that the hole looks the same size as the hole used for the sway chain. Maybe JD uses these draft links for another tractor where the sway chains hook into that hole or maybe if you wanted to use that hole instead you could. Other than that I have no other idea since the drawings do not specify anything regarding this extra hole.
   / Need info for 3-pt on a 990 #15
Hi Ak old bud and JP,
An old VW bug hood (upside/down) is great bull nose for skidding logs.
cheers,
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
2006 MILITARY SERVICE TRAILER (A52708)
2006 MILITARY...
BUSH HOG 5' SQULAR ROTARY MOWER (A52708)
BUSH HOG 5' SQULAR...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
LOT OF FIRE EXTINGUISHERS (A58374)
LOT OF FIRE...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
